fast flash blinkers, normal hazards
Old Nov 28, 2008 | 06:11 PM
rickkane's Avatar
Default 2nd post by mistake! fast flash blinkers, normal hazards
posted twice by accident. Sorry. Use the first one
So when I use my turn signals they flash super fast, but when I turn on my hazard they flash as normal. I don't like the fast flashing. I don't have any bulbs that are burned out. I have tried swapping all the bulbs, and replaced the flasher relay at the fuse panel in the car. Does anyone know how to fix this, or what I might have missed in my attempts? Or does anyone know which ways to make this happen so that I can maybe try to reverse it? Thanks for the help...
Last edited by rickkane; Nov 28, 2008 at 06:13 PM. Reason: posted twice by accident
Old Nov 28, 2008 | 06:18 PM
wangkata's Avatar
check the ground or open wire...my car has same problem but I fixed it when I turn left it flash fast but when I turn right its normal, hazard normal so I checked the ground sure enough one of the ground busted on left front turn signal....
Old Nov 28, 2008 | 06:30 PM
Paul1985's Avatar
You sure you havent missed a globe somewhere??
Does it indicate fast both on the left and the right?
Old Nov 28, 2008 | 06:34 PM
rickkane's Avatar
Yes, left and right is fast. Hazard is normal.
Old Nov 29, 2008 | 12:45 AM
Paul1985's Avatar
I'm not too sure but is it possible you may have the wrong kind of globes used somewhere?
Old Nov 29, 2008 | 11:03 AM
JJ's civic's Avatar
i had the same prob but my pigtails where both green with cororsions
Bambooseven
Mar 3, 2009 08:40 PM
rickkane
Nov 28, 2008 09:31 PM
ChrisHatchback
Apr 12, 2005 08:34 AM
mike5809
Dec 17, 2003 05:16 PM
