My build thread-1991 usdm honda crx si d16a6 sohc zc all motor N/A
Old Nov 28, 2008 | 05:22 PM
acmoc's Avatar
Default My build thread-1991 usdm honda crx si d16a6 sohc zc all motor N/A
This is my build thread, I'm pretty into it already, but I will just update you guys to now over the days k.
It started pretty slow but has picked up pace, and I estimate I will be done in one year two tops.
Anyways, this is my thread, this is my car; a 1991 Honda crx si. I did a carfax on it, and I'm the second owner, car has a clean history and made it's way over here from Canada, picked it up from an old lady for 1800.00 a year back
Here's my first pics.
I think no one respects the d series so I'm sticking with it, just to be a little unique. I was really interested in supercharging, but just going to keep it all motor
Old Nov 28, 2008 | 07:16 PM
EFstyle's Avatar
nice man... interested to see how you go about doing it... Dirty D FTW!!
Old Nov 28, 2008 | 08:31 PM
acmoc's Avatar
Well it's not the original d16a6, it had 142 k on it so I decided to buy a Japanese import, the sohc zc. My dad owns small auto shop and I bought one from his wholesaler for 250.00 with the transmission.
But the d16 still worked, so I we installed an exedy oem clutch, and race flywheel. I should've bought and Lsd while I was at it, but didn't know what to look for (still don't =[) .
Anyways, first things first, was a major tune up for the new motor, well 40 k mile motor
This involved Everything; including a complete engine seal.
sparkplugs, wires, dizzy cap, rotor, O2 sensor, pcv valve, fuel filter, timing belt, and fuel injectors.
We put the motor in the car and finished doing the tuneup, fluids mainly. And went to pass smog... I failed. so instead of fixing it and going for my free re-test, I bought these:
Old Jan 5, 2009 | 09:33 PM
acmoc's Avatar
Default Re: My build thread-1991 usdm honda crx si d16a6 sohc zc all motor N/A
suspension is what has been done mostly since i kept the d series, I thought I would compensate
I have now, this setup;
blox lca's, rear camber kit
skunk2 front camber kit
no name strut bars
tanabe sway bars
tein basic dampner
mugen trailing arm bushings
at one point I installed some innovative engine mounts, but the vibration was annoying, so I removed them
My innovative traction bar and front mount is set to arrive soon
Old Jan 5, 2009 | 09:37 PM
acmoc's Avatar
Old Jan 6, 2009 | 04:12 AM
carnz98gsr's Avatar
good selection of parts there and that's a nice clean crx! lookin good so far man
Old Jan 6, 2009 | 06:50 PM
acmoc's Avatar
Yea thanks, I do all the installs myself mostly, so it's too bad I can't take more ppiocs of the install process
Old Jan 6, 2009 | 09:41 PM
clubef9's Avatar
Default d16a6 sohc zc all motor N/A!
Good stuff there and glad to see another fellow D follower! Get to the motor work already!
Old Jan 6, 2009 | 10:07 PM
acmoc's Avatar
Default Re: d16a6 sohc zc all motor N/A!
still been working on the suspension a bit,
The motor is a stock sohc zc, with a exedy oem clutch and race flywheel
Id on't know if it's like this stock, but someone said my flywheel is why I have to rev my motoor so much to keep it from bogging, it's nice otherwise
Old Jan 6, 2009 | 10:10 PM
acmoc's Avatar
This is the most recent picture of my motor
But that setup was real bad, for power and mpg. So rite now it has the stock manifold and throttle body
ebay headers are pretty good for the price
Old Jan 6, 2009 | 10:23 PM
acmoc's Avatar
this is my current motor setup;
Ground wires; pic above is old, wire goes to crown bolt
aem cam gear +1 degree
aem cold air intake
aem pulley
aem fuel rail, fpr set to 43-44 psi
new radiator, slimfan, high pressure radiator cap, 70/30 mix with water wetter, and 160 degree thermostat
stock d16 manifold throttle body, with bypassed coolant lines
insulated fuel lines and fuel filter
valvoline 5w30 synpower
penzoil synchromesh
gates hoses, and timing belt
ngk plugs, o2 sensor, and wires
blox drain plugs [placebo]
tsudo catback
I found bisimoto sells heat insulating manifold gaskets, so i want one of those.
I plan for an lsd and a ceramic coat on the header, I planned on lightening my crank pulley also
but not sure on this yet
an lsd and crank pulley will be done for sure if i have to pull the motor out
this on order soon to arrive;
es shifter bushing
oddysey pc680 battery
i've been looking into testpipes, not sure if it's worth it, feedback anyone?
Old Jan 6, 2009 | 10:28 PM
clubef9's Avatar
Ah nice! I may have to show you my A6...But ya, Bisimoto sells great stuff! Can't go wrong there. I have one of his cams in mine, hehehe
Old Jan 7, 2009 | 12:23 AM
TeamProjectZero's Avatar
Dam nice D Man Got My 88 Hf Like that kinda same parts but mine is the d15B7 Gotta Go Get A D16A6 But thinking of getting the D15B
Old Jan 7, 2009 | 03:49 AM
fireant's Avatar
Good stuff!
What are the brass things on the front of the valve cover?
How heavy is the race flywheel?
Old Jan 7, 2009 | 07:51 AM
acmoc's Avatar
Originally Posted by fireant
Good stuff!
Those are ground cables, wired wrong. None were touching the cylinder head. Now I have them connected to the crown bolts. I will update pics soon
The flywheel was 10 pounds or so.
Old Jan 7, 2009 | 07:53 AM
acmoc's Avatar
Lowered a little more than this rite now
Old Jan 7, 2009 | 08:57 AM
savage3006's Avatar
looks nice man, almost makes me not want to swap from d to b
Old Jan 7, 2009 | 08:03 PM
acmoc's Avatar
/yep, d series is very reliable.
sad to say, but I cracked my heater control two days ago, it was already cracked but I finished it.
went to honda and they had one in stock. so here's a pic of it for you guys to drool over. lol jk
Old Jan 7, 2009 | 08:05 PM
acmoc's Avatar
I found a thread by crx toad that helped me allot in installing it, good thing I found it when I put the new one in.
edit; Here it is
http://mdkeena.dnsalias.com/plate/index.htm
Old Jan 7, 2009 | 08:19 PM
Turbo Dan's Avatar
how much did you pay for the new climate control?
and you seemed like you were joking but i actually did drool over the pics of the new one.
i didn't know brand new climate controls existed, never mind are in stock at dealerships!
nice score
i wonder if there is anything you can do to the new one so it doesnt suffer the same fate as all CRX climate controls?
maybe epoxy on the rear of where it tends to crack?
Old Jan 7, 2009 | 08:42 PM
acmoc's Avatar
nice score
it was pricey, 330.00
I didn't know either, but I got lucky. Good thing because I wouldn't be able to fix mine
Old Jan 7, 2009 | 08:57 PM
Deetz's Avatar
Crazy Honda Guy
Car is coming along well, good stuff. I too bought a new climate control, not sure why people think they can't just order one. There are many parts that can still be had NIB at Honda. Last month i picked up a new area cover top and bottom parts too.
Good luck with your build.
Old Jan 7, 2009 | 09:00 PM
DatatRex's Avatar
Nice! What kind of exhaust do you have?
Old Jan 7, 2009 | 09:19 PM
acmoc's Avatar
tsudo n1
ut I really really really really want something stock like tanabe hyper medalliion. but its pricey =[.
are you local?
I''ll buy the tanabe and sell mine to you for 100.00
edit; no you're not =[
Old Jan 8, 2009 | 03:13 AM
rbwdriven's Avatar
is it me or do you have duct tape holding your cold air kit to the throttle body?
They do make silicon connectors for that if that is the case.
