Something is wrong here...
Old Nov 28, 2008 | 02:52 PM
slammedeewagon's Avatar
Icon2 Something is wrong here...
I have a problem i replaced my dizzy not to long ago well i rebuilt it, ok today i got and start it it sounded like a subie but it was kinda cold out so it stopped when it got warm car ran fine all the way to work about 10 miles, i pull in my spot and bam shuts off. well i turn it on runs fine, come out for lunch starts runs fine until i get to bk and shuts off pissed as i am it starts again i go back to work as im waiting at a light again it shuts off. starts right up again go in to work come out to go home same thing runs fine waiting at a light again off. it was doing after like 1 min of ideal now its like 30sec i really need help some one help me out. and it sounds like it want to run when its about to shut off but i makes a loud sucking noise a shuts off im stumped
Old Nov 28, 2008 | 03:35 PM
89s1's Avatar
umm sentance structure?
I read the first 2 lines then I had a seizure. Learn to make a decent post.
Old Nov 28, 2008 | 05:29 PM
well thanks for the help.
Old Nov 28, 2008 | 05:41 PM
sgallagher's Avatar
When you say you rebuilt your dist. what exactly did you do? Do you have a Check engine light?
Oh and your post is a little hard to read..
Old Nov 28, 2008 | 06:13 PM
i think it might just be the coil the only thing i didnt change
Old Nov 28, 2008 | 06:46 PM
Jarrat's Avatar
Sounds like you need to take it to a mechanic.
Old Nov 28, 2008 | 08:20 PM
yeah so they can have my car for 2 days and tell me that i need to pay them 1500 for a coil
Old Nov 28, 2008 | 09:52 PM
ivanson's Avatar
check if your MAP sensor is hooked up or block off.
check the vacuum to it and the connector/wires
Old Nov 28, 2008 | 11:06 PM
Black02LS1's Avatar
Soulds like an intermitant misfire. Check the cap for any obvious burns or arc marks. If so, then replace.
Old Nov 29, 2008 | 05:24 AM
yeah getting towed today so im going to be working on it all day. going to be getting a dizzy if it keeps up vacuum is next.
Old Nov 29, 2008 | 03:21 PM
hfcrx88's Avatar
I'm 95% sure it's your distributors.
The symptoms sound the exact same as when my dizzy went bad.
I know they are expensive, but just suck it up, go to Autozone, or Advance or something and buy a dizzy. At least then it will have a lifetime warranty.
Warranty is a good thing man, especially on dizzys and axles.
GrantMC2
Feb 5, 2015 08:28 AM
Needhelpplease1
Nov 17, 2013 06:59 PM
Deimus
Apr 4, 2007 04:33 PM
frog169
Jun 9, 2006 10:02 PM
