how do i put a front sway bar from a CTR on?!?
i bought a 26mm front ctr sway, i already have the si control arms and forks installed, but the bar doesn't seem to fit no matter which way i try to put it in, the frame gets in the way every time!
is the ctr front sway even suppose to fit on a 00 dx?
i hope you removed your exhaust/shift linkage before trying...
seems everyone on this forum who installs a front sway bar puts it on upside down.
and i have no idea if it will fit or not, think you should've probably asked that before purchasing it eh?
well after searching heavily and reading up that EK sway bar faq the SI and CTR sway bars and lca's should be the same, and yea i did d/c the sl and pipe but just doesn't seem to fit because the frame keeps interfering
i own a true ek9, depends what sub frame your running if your running an oem subframe for example oem cx or dx? you can probaly get away with switching your front lca's with an SI or 99/00 honda crv LCA's si's and crv's are both identical lca's then you will be good on running that sway bar. I hope this helps u out
Halo
Nov 7, 2004 09:26 PM
Halo
21
Dec 7, 2001 03:28 PM
