Car will not crank
Old Nov 28, 2008 | 11:29 AM
mrsb1993's Avatar
Icon2 Car will not crank
Summary:
Bought a 1993 Del Sol 1.5 on Saturday. Passed smog and got registered on Monday. Car died on Tuesday. Changed battery on Wednesday - Will not crank. Tested Alternator and Starter - Good. Checked timing - Good. Changed distributor (I noticed a lot of people talking about the control module within the distributor - didn't want to mess with it so I just changed the whole distributor) - Will not crank. Any ideas?
Old Nov 28, 2008 | 11:34 AM
revhardallday's Avatar
check your ground wires the big ones theres one from head to front radiator support and theres one from the tranny to the side of the fame near the tranny mount.
Old Nov 28, 2008 | 11:35 AM
davefromPA's Avatar
main relay, ecu itself, bad ground. three things to check off the top of my head
Old Nov 28, 2008 | 11:36 AM
davefromPA's Avatar
there is also one built into the wire harness that connects to the thermostat
Old Nov 28, 2008 | 11:39 AM
mrsb1993's Avatar
Ok. Grounds are all good. Bolted down nice and tight. Is it possible this car is a "lemon"?
Old Nov 28, 2008 | 11:41 AM
yup make sure the one on the thermo housing is there too ive cars not starting because of it..
Old Nov 28, 2008 | 11:42 AM
how did you check the starter?
Old Nov 28, 2008 | 11:45 AM
mrsb1993's Avatar
Alternator and Started checked at Autozone
Old Nov 28, 2008 | 11:50 AM
mrsb1993's Avatar
Is it possible the Alternator and/or Starter are bad, but for some crazy reason they passed at Autozone?
Old Nov 28, 2008 | 12:12 PM
mikehawk's Avatar
is it completely dead? does it turn over? fuel pump prime? does it make any noises when you try and start it clicking etc??
Old Nov 28, 2008 | 12:32 PM
mrsb1993's Avatar
When I turn the key I can hear the fuel pump click and the starter click, but that's about it.
No grinding nothing...
Old Nov 28, 2008 | 01:14 PM
mikehawk's Avatar
id replace the starter.
Old Nov 28, 2008 | 02:15 PM
mrsb1993's Avatar
Ok... installed new starter. Still will not crank over... ?
Old Nov 28, 2008 | 02:45 PM
when you turn the key all the way all you here is a click from the starter?
try this take a jumping cable and connect one side to the negative side of the battery and the other side to the starter case and try to crank it.... if it cranks you have bad grounds.....
Old Nov 29, 2008 | 04:40 AM
honda.lioness's Avatar
Eliminate a faulty main relay using the quick checks at http://www.tegger.com/hondafaq/start...html#mainrelay
Check all wiring connections of anything you have replaced or messed with recently.
Check for stored codes in your ECU.
Where did you buy the distributor? Check the exchange policy on your new dizzy and see if you can try another one. Bad ones are sold by accident from time to time.
Autozone staff unfortunately can definitely screw up alternator and battery checks.
Hondas are not prone to being lemons. It is more likely that something you did recently messed up the car a bit. Some simple little thing. The alternative is that the previous owner monkeyed with your new used Del Sol, and you have to undo whatever mischief s/he created.
jacoblytle
Jun 29, 2014 04:36 PM
xOtakuBuster
Oct 16, 2011 08:41 AM
soLaLive
Dec 8, 2010 03:13 PM
NickTJohnson
Feb 21, 2008 08:50 AM
erikiksaz1
Dec 25, 2004 06:25 PM
