zc in a 4g civic help me!
Old Nov 28, 2008 | 10:43 AM
jakescivic's Avatar
Default zc in a 4g civic help me!
i bought a 1990 civic si with a blown engine for dirt cheap i ordered a DOHC zc engine for it ( this is my first swap by the way) but now im a little confused on the wiring .i bought it from hmotorsonline.com and they just cut the harness in half . how do i get all my wires to match up. The plugs are different sizes and shapes
Old Nov 28, 2008 | 10:45 AM
digitally_remastered's Avatar
use your original harness from the old motor and add the required plugs if need be. take a look in the faqs section to figure out what you need to do. its not hard to swap an engine even if it is your first. take a ponder in there, there is tons of information to be had.
also is/was your car dpfi or mpfi?
Old Nov 28, 2008 | 12:59 PM
hailchristian's Avatar
if you have a civic Si, then the only thing you will really have to change is the distributor wiring.
You should already be at Multi port if you are at a civic si.
check this out
http://fourthgenhatch.net/zc.html
Old Nov 29, 2008 | 12:02 PM
jakescivic's Avatar
how do i find out if it is mpfi dpfi
Old Nov 29, 2008 | 12:53 PM
Radim's Avatar
DPFI has a carburetor-like manifold with two injectors, MPFI is a smaller regular looking manifold with 4 injectors.
Here's my MPFI-Swapped Civic if your manifold is taller with a black covering it's DPFI
Old Nov 29, 2008 | 03:03 PM
jakescivic's Avatar
ok then i have a mpfi on the d16a6 i took out and on the zc
Old Nov 29, 2008 | 03:11 PM
31flavorscivic's Avatar
it's a straight swap over. Car should start right up. If it doesn't crank it for like 5 minutes and it'll fire; sometimes the engines sit for a while and are a little hard to get going again.
Old Nov 29, 2008 | 03:23 PM
jakescivic's Avatar
ok great! What about the distributor plugs how do i get those to fit
Old Nov 29, 2008 | 05:19 PM
Oh cripes. Mine just plugged right in, but someone might have done something weird to my car before.
ummmmmmmmmmm
you can depin the plug and get the one off the old harness and put the pins in? Just match the colors up. THat's my best advice.
Nooch
May 27, 2010 09:55 PM
goforbroke
25
May 9, 2010 09:23 AM
Dspad_91Civic
May 7, 2004 05:12 PM
gregv
Sep 11, 2002 03:24 AM
vtec_head
May 8, 2002 08:59 AM
