spark problem
Old Nov 28, 2008 | 09:43 AM
revhardallday's Avatar
Default spark problem
hey i been having this problem with my car..
start it up and drive around for more then 15 mins car will just shut off, then i try to start it and it just cranks... i have fuel pressure... let the car sit for 30 mins then it will start up but when it gets warm it dies.....
so then i replace the coil/module inside the distributer and it seem like it worked i drove the car for 4 days and it never died... now its doing the same thing again... i have a new coil/moduel new plugs new wires and a new cap and rotor...... im thinking the distributer it self might be bad...
any info will be appriciated.... thnaks
Old Nov 28, 2008 | 09:51 AM
also will the pgm relay (main relay) give you fuel pressure but no spark.....?
Old Nov 28, 2008 | 10:10 AM
honda.lioness's Avatar
To eliminate the main relay so you can keep going forward in your diagnosis efforts, do the check given at http://www.tegger.com/hondafaq/start...html#mainrelay.
Are your new ignition parts OEM?
If you messed with the new coil much, it is possible it is already damaged. Check it per http://www.tegger.com/hondafaq/start...s.html#badcoil
Are there any engine codes?
MechEng
Oct 26, 2013 01:25 AM
OkayTrash
Dec 30, 2011 09:11 AM
olschool92
Jul 25, 2011 02:38 PM
thunderlips
Aug 28, 2009 01:29 PM
live_again_integra
Jan 4, 2007 05:42 PM
