91 ef cant open hood need help
the latch to pop the hood wont open the hood. it seems like the wire behind it is frayed or something and there is no pressure to open it. anyone know what i can do it get my hoop open. thanks alot
Stick your hand through the front bumper and see if you can find the cable. If you can find it try to pull it straight down, if it doesn't want to unlatch push down on the top of the hood a little. I had some work done to my car recently and when I got home to look over everything again, I couldn't unlatch my hood either. I had a new radiator installed so I guess something got put out of place, I don't know, but anyway this is how I opened it when my release inside the car wouldn't work.
If you can still get tension, then make sure the cable is fastened securely; maybe stick a 2x4 of appropriate length in there to secure it well. Then pull hard on the cable end stop with pliers. This should pop the hood. Getting the right leverage is a little tricky, but the 2x4 should help.
Plan on replacing the cable. It is not a hard job. See the writeup at http://honda.lioness.googlepages.com/hoodreleasecable
BlitzSix
Jul 16, 2018 05:22 AM
Ej1Stolo
Aug 16, 2010 05:15 PM
