Turn Signal Auto-Cancel? PLEASE HELP!!!
Old Nov 27, 2008 | 07:59 PM
jclark5093's Avatar
Icon3 Turn Signal Auto-Cancel? PLEASE HELP!!!
========SHORT VERSION=========
My signals do not auto cancel. We tried replacing the MF switch. That didn't work. This only happens in cold weather. I have "loose" steering which is definately related. It is always temporary (it will work 4 months from now).
==========LONG VERSION=========
so I found out that if your signals don't auto cancel (if originally designed to do so) in Pennsylvania, you fail the test.
[[edit -- hahaha I forgot to say what car I have!!!! '97 Civic Ex Coupe, D16y8 (sohc vtec) automatic, many system failures....lol]]
Here's the story - for the past 2.5 years, every winter, my signals don't auto cancel, and I switch them off myself. Every spring/summer time, they start working again, until it gets back to winter. I don't know if this is temp related or not, but its not working yet again.
Usually, when the signal don't auto cancel, its because the fingers brake off the gear widget, right? anyway, they're not broken off, because it miraculously works again in 4 months.
OTHER SYMPTOM===
when the signal stops working, my steering gets loose. Well, the steering wheel to wheel turn ratio is proper, but it feels jello-ey. Like I need less muscle to physically turn my steering wheel. Also, now that its broke, my steering doesn't automatically return to straight atfter a turn (well it does, but not as well as it used to whip back to neutral).
These steering alterations may or may not be temp related as well, but they only change EXACTLY the same time. every year, I notice my steering is wacky, so I'm like great - means my signals a popped - and sure enough...
ANYONE KNOW ANYTHING ABOUT THIS?? My mechanic hardly believes me, so he sold me a new multifunction switch, and 300 bucks later, still nothing (got my refund, don't worry)
is there a clutch type thing around the steering column to register the turn signal? and also tighten the steering? thats what it feels like to me, but I've never been inside the steering column of a car in my life, so I've no clue.
My inspection is past due, please hurry with help!!!
Last edited by jclark5093; Nov 27, 2008 at 08:38 PM. Reason: added short version to OP
Old Nov 27, 2008 | 08:06 PM
93egboosted's Avatar
idk i read half your post you wrote to much for something to small of a problem. umm its problay the acutal control behind the steering wheel my 00 si is the same way but i never botherd fixing it
Old Nov 27, 2008 | 08:38 PM
jclark5093's Avatar
this is required for inspection... sorry I wrote so much, but it is a complicated problem, which required a complicated description.
Old Nov 28, 2008 | 02:36 PM
jclark5093's Avatar
bump? guess nobody's on black friday... all too busy at pep boys, eh?
Old Nov 28, 2008 | 02:39 PM
jeremyrocksursox's Avatar
hell no, pepboys sucks major D***
Old Nov 29, 2008 | 08:37 AM
jclark5093's Avatar
bump - some help this time maybe? This forum used to be so active and useful a couple of years ago... (this is a new tag, i forgot my password...)
Old Nov 30, 2008 | 01:36 PM
jclark5093's Avatar
bump. thanks guys.
Old Nov 30, 2008 | 03:16 PM
ReDemoN's Avatar
DixielandImports Please
Try replacing the little white thing behind the steering wheel.
I dont know what its called but try that.
Old Nov 30, 2008 | 06:49 PM
The_Honda_Guy's Avatar
Have you taken out the clockspring and checked it out? There's a tab on the clockspring that will hit a tab on the multi-function switch to cancel the turn signal. My guess is possibly the tab broke off one of them and is not canceling the signal. Check there.
Old Nov 30, 2008 | 10:34 PM
jclark5093's Avatar
That was my first assumption, and I didn't care to repair it, so I replaced the switch. if Either part is "broken" though, it would not explain how the system miraculously works in the spring time... if it is shifted out of phase, or somesuch, this might make sense...
Maybe I'll have to rip the wheel off and take a look once and for all... I just really want to know what I'm looking for before I do...
Old Dec 1, 2008 | 03:12 PM
Clocksprings are relatively easy to do as long as you have a gear puller/steering wheel puller. I've done a few of them as recalls on the Chrysler vans.
All it involves on those is removing the airbag section of the steering wheel via the bolts on the backside of the wheel, unplugging the connectors from the clockspring that go to the horn, cruise, airbag, etc., removing the nut holding the steering wheel on, then using your gear puller to pull the steering wheel off the column, then removing the plastic bezels around the multi-function and wiper switches, then removing the clockspring. It's pretty basic to do and should only take you an hour at most.
Old Dec 1, 2008 | 06:35 PM
jclark5093's Avatar
hmm... is this in the haynes manual? I'd love to see some pics before I go screwing around in there... (I know the wheel/srs removal and replacement is there, but is the clockspring thingy?)
if anyone knows any pic sets/tutorial/threads to link, that would be infinately appreciated!!!
jclark5093
Feb 22, 2011 06:00 AM
jclark5093
Dec 6, 2008 09:30 AM
crapanese
Sep 14, 2008 01:33 PM
allen1466
Honda Civic (2001 - 2005)
Mar 19, 2008 10:11 AM
mxjoe388
Sep 12, 2007 05:58 PM
