gsr or itr throttle body
Old Nov 27, 2008 | 05:51 PM
eg customs's Avatar
Default gsr or itr throttle body
whats better on my eg turbo. a gsr throttle body or a integra typer R. any comments suggestions
Old Nov 27, 2008 | 06:14 PM
hybridmath's Avatar
type r it has a larger bore which means more air into the motor
Old Nov 27, 2008 | 06:24 PM
American.Graffiti's Avatar
This answer is incorrect to an extent. Just because the air flow inwards through the throttle body is increase it is not correct to assume that the airflow through the intake manifold runners and intake port will also experience larger amount of intake airflow. There is more than just upgrading a tb to increase airflow. If anything concentrate on the air velocity. A itr tb will only help with throttle response when paired with a stock intake manifold. Think about it in this sense, if you have a large door leading to a small hallway does that mean you can fit more through the door with no regards to the hallway itself?
Old Nov 27, 2008 | 06:28 PM
EFRue57's Avatar
also a gsr throttle body will only work on a gsr intake manifold because of the way the throttle cable hooks up. just thought i'd through that out there.
Old Nov 27, 2008 | 07:00 PM
T3KNiQe's Avatar
ITR TB and intake manifold.
Old Nov 27, 2008 | 07:03 PM
93egboosted's Avatar
not so true my buddy has a ls tb on his gsr im with the gsr throttle cable bracket and it works fine
Old Nov 27, 2008 | 08:39 PM
EFRue57's Avatar
yea sorry i guess i didn't word it right it will work but will require modification. also he probably has another throttle body but if he didn't it would require him buying 2 throttle bodies to make one work. but thanks for correcting my poor phrasing.
Old Nov 27, 2008 | 08:44 PM
we put together his ls/vtec and he only had a ls tb and we bolted it up and it works fine
Old Nov 27, 2008 | 09:26 PM
EFRue57's Avatar
dammit i can't think right tonight. you're right, all he needs is the bracket. i need to go to sleep or something because i don't know what the hell i'm thinking of as far as t/b is concerned. thumbsdown to me for poor information.
Old Nov 27, 2008 | 09:28 PM
all good in the hood man i kno how u feel
Old Nov 28, 2008 | 06:18 AM
pdiggitydogg's Avatar
Or you could just swap the cable pulley from any other tb in place of the gsr pulley. That is really the only difference.
Old Nov 28, 2008 | 07:03 AM
wrenchez81's Avatar
they are both 60mm stock i thought.... guys correct me if im wrong ... but i thought all d series were 56mm,,, b,f and h series were 60mm,, and the s2k's were like 70mm stock.. in fact i was told a quick and cheap upgrade for a d series is to swap out any b or h series tb because theyre 4mm larger... and bolt right up.....
Old Nov 28, 2008 | 06:35 PM
eg customs's Avatar
but where does a s2k's come from. what kind of car
Old Nov 29, 2008 | 03:58 AM
wrenchez81's Avatar
the USDM Honda S2000
Old Nov 29, 2008 | 07:10 AM
fryguy190's Avatar
ur probly gona laugh but i put a GSR throttle body on my z6 manifold. and it works great no leaks...
SSGojeta
Dec 27, 2008 09:29 AM
Elevorett
Apr 14, 2007 01:29 PM
TimeRacer
Nov 17, 2002 08:19 AM
