Project 99 TURBO Civic SI
Just purchased a 99 Civic SI and need to know a few things.
Engine:
B18A2
Here is my kit:
Treadstone B Series Cast Manifold
Treadstone TR8 22" 8" 3.5" bar and plate 2.5" in and out FMIC
Turbonetics T3/T4 Exhaust A/R .48 V Trim T04B
Turbonetics Evolution 35mm WG
Treadstone IC Piping Turbo to TB
Type - RS BOV
550cc Injectors (What Brand?)
Support:
Dyno Tune Chrome Pro? what other choices?
AEM Wideband
Autometer Boost gauge
Transmission:
ClutchMasters FX-300
LSD (What Brand?)
MY QUESTIONS?:
What about Fuel Pump?
Anyone ever herd of using a kenne bell boost-a-pump?
http://www.kennebell.net/accessories...boostapump.htm
What about exhaust?
How much HP and TQ can the SI pistons and Rods withstand?
I have read about spark resistors, what is this and do I need it?
I read the sticky's and learned a lot. Sorry if some of these questions were in there.
Engine:
B18A2
Here is my kit:
Type - RS BOV
Support:
AEM Wideband
Transmission:
LSD (What Brand?)
MY QUESTIONS?:
What about exhaust?
32 views and no one has any opinions?
I'm new to the Honda world and looking for reputable companies. So please some input. Both Positive, and Negative comments with supporting factors are welcomed on any parts you do not see fit.
Engine:
B18A2
Here is my kit:
Type - RS BOV
550cc Injectors (What Brand?) BOSCH 1000CC NO RESISTOR BOX NEEDED
Support:
Dyno Tune Chrome Pro? what other choices? whatever your tuner recommends
AEM Wideband
Transmission:
ClutchMasters FX-400 OR COMPTITION STAGE 5
LSD (What Brand?) QUAIFE
MY QUESTIONS?:
What about Fuel Pump? WALBORO 255
What about exhaust? 3INCH DOWNPIPE AND EXHAUST
Engine:
B18A2
Here is my kit:
Type - RS BOV
Support:
AEM Wideband
Transmission:
MY QUESTIONS?:
no need for 1000cc injectors, way too much for his power goals unless he plans to run e85
if you plan to run below 300whp dsm 450cc will work or get precision 525 or rc 550
if you are going to spend money on crome pro might as well get ectune (much better)
If you don't want to spend $500 on the clutch get competition clutch (nice clutch for the money).
Also OBX lsd or mfactory lsd is way cheaper then qualife. If you get OBX take it apart and inspect.
Search before you post. Just look at other people setups and copy. BTW you need alot more stuff then that to finish your kit.
research before you just start ordering parts
well you have to build a turbo setup with in your power goals. It's easy to overbuild and the car is going to be a pain the *** to drive (too big of the turbo (no spool on small motor), too hard of a clutch (no slip, hard to drive), too big of injectors (I know bosch are supposed to idle fine and not run rich as hell). If you want more power just pull the **** out sell it, and build a new setup from scratch. The motor needs to be built anyways, needs new manifold, turbo, wastegate. Will need to redo downpipe and dump tube. Just build it to your power goals car will be quicker and easier to drive.
that setup will work, I'm just iffy about expense that's used for clutchmasters clutch (those are **** load). I like competition stage 5 clutch it feels nice, but the wear and tear you put on that clutch is pretty crazy when you drive it daily and race it with not alot of grip in tires. Racing on 22 inch slicks on the street and daily driving resulted in that clutch almost touching the rivets in like 15k miles. I like non puck clutches for anything less then 350whp because they last longer. And even though bosch 1000cc injectors sound like the best 1000cc injectors out there they also come in a big price $460, instead of $50 he can pay for dsm one good for 300whp, or $280 for 525cc.
Joeski99Si
Sep 9, 2010 09:35 AM
