axel removal eg!
Old Nov 27, 2008 | 02:32 PM
hondaEg_808's Avatar
Icon6 axel removal eg!
this is my first swap and i tried searching axel removal but can seem to find any! well i disconnect everything that was connected to the motor but the only thing holding me back is the axels! i removed the axel nut is it? correct me if im wrong! it was pretty hard to remove it but manage to get it off !! but anyways heres the part i need help on how do i remove the axels?? please help me out thanks!!
please keep negative comments to yourself thanks!!
Old Nov 27, 2008 | 02:37 PM
INCNTRL4's Avatar
take off lower ball joint nut, take a hammer to the lower control arm to get the ball joint to pop out. pull the knuckle away and pull the axle out, may have to use a pry bar on the back of the axle.
im sure there is how to's on here somewhere.
Old Nov 27, 2008 | 02:45 PM
z6hatchboy's Avatar
yeah, undo the upper ball joint and tie rod end. Take the axle nut off, lean the knuckle out then pull the axle out
Old Nov 27, 2008 | 02:54 PM
BryanM.'s Avatar
Resident Gearhead
Thank B18C5-EH2 for this great tutorial:
https://honda-tech.com/forums/showthread.php?t=382416&highlight=axle
You don't need to do anything with the upper ball joint or the tie rod end. Sounds like an unorthadox method
Old Nov 27, 2008 | 03:00 PM
Sean @ ESG's Avatar
Spell axle correctly in your search and you might have better luck
Old Nov 27, 2008 | 03:50 PM
thanks mcvtec!! this helped alot!!
Old Nov 27, 2008 | 04:22 PM
BryanM.'s Avatar
Resident Gearhead
You're welcome
White_EG1
22
May 21, 2018 10:20 AM
Alcatrax30
Nov 9, 2014 05:38 AM
slow_low_eddie
May 5, 2014 01:26 PM
C_Rock77
Aug 27, 2008 11:19 AM
B18CYAAA
Nov 25, 2006 01:22 PM
