RC Injectors in d16y8...which injector o-rings?
Old Nov 27, 2008 | 02:11 PM
EX-T's Avatar
Default RC Injectors in d16y8...which injector o-rings?
As the title says, I have a y8 with RC 550s in it, I used the y8 o-rings but they don't fit right and it leaks fuel. If I get d16z6 o-rings will the be the proper diameter for the intake manifold and the injectors to seat properly?
Old Nov 27, 2008 | 05:43 PM
portenio78's Avatar
Get the thinner bottom RC o-rings and you'll be golden.
Old Nov 27, 2008 | 05:46 PM
K i l l a B e e.'s Avatar
find one that fits the diameter of the hole on the IM and bore it out to fit the rc's
Old Nov 27, 2008 | 07:03 PM
EX-T's Avatar
Will the Z6 o-rings work since they are OBD1 and so are the injectors...
Old Nov 28, 2008 | 07:19 AM
portenio78's Avatar
If you already have the other z6 o-rings, then yes you can "make" them work. If your going to buy a new set, just buy the RC ones since they are designed to sit on thier injectors better.
cmc600rr
Mar 16, 2010 04:41 PM
faxshatch
Mar 16, 2008 05:37 PM
big-cat
Nov 3, 2006 07:17 PM
murmur9
Sep 26, 2004 08:28 PM
FAST AS
Dec 22, 2003 07:43 PM
