FS Snow Performance Boost Cooler custom
Hi guys,
I have this snow performance injection kit that was never used and stored for a while now….i realized I don’t need it any more and would like to sell it! The kit I got is custom and will sell all of it as a package! The package contains:
1-Boost cooler stage 2 with custom VC-100 control unit with its std tank (P/N: 20010)
Ready to control injection upto 30psi of boost
2- Safe Injection unit (P/N: 30010) modified by Snow Performance to read upto 3BAR
3- Safe Injection Bypass Valve Solenoid kit (Wastegate type)
(P/N: 30100)
4- Boost Cooler Level Switch (P/N: 40030)
5- Dual Nozzle Upgrade and nozzles (each nozzle is marked RED so each nozzle is 375 ml/min) this nozzle kit is for those serious apps who run HIGH BOOST!
6- Large 7-qt Reservoir (P/N: 40020)
7- 220psi upgrade pump (std pump is 150) ( PAT.NO.4,610,605)
Cleaned the pump up and tested and its working perfectly
All wirings are still in perfect condition (nothing spliced or cut), all cramps are there, tubings, hoses, Thread tap, screws ….everything is still in the package!
There are a few things the buyer should know before purchasing this kit:
1- That I was trying to install the kit so the only two things that look used is the nozzle was installed on the quick connect fittings and has a little of dust since it was stored (just clean it using carb spray and it should be clean!)
2- pump was mounted on the car for one day (didn’t drive the car with it on)! Just powered it once to check the pump is working and IT IS !!!! the control units are perfectly new (not even one scratch), so you will know this kit is 99% NEW!
3- Injection push type tubes are cut since I was trying to install them
That same day I realized am taking things in a hurry and decided to remove the pump and store the whole kit and then months started to pass by….lol
Buying this package will cost +$1000 WITHOUT SHIPPING!!!! and I will let this whole package go for $600 shipped anywhere in the US
I accept paypal so PM me quick before this kit goes !!!!!!!
(P/N: 30100)
Outkast95LS
Northern California (Sales)
Apr 8, 2008 12:30 PM
