Skunk2 stage 3 cams
Does any one have any experiance with using the old style skunk2 stage 3 cams in a boosted motor ? I have a set so I figured I might as well use them.
Running a b18c block 81.5 bore cp 9-1 pistons. built b16a head with skunk2 valve train and valves also fully ported and poilshed and port matched to the intakemaifold. Turbo set ups ram hornmanifold tial 38 and 2871R with the .63 a/r
I am also wondering what I should dail the cams in with the cam gears
Are these the Pro or Tuner version? In any case, my own opinion these will be very agressive for a boost application & you might also find the car not that desirable for daily use, to least say it will be bit lumpy on idle and considerably loud.
MadHead
Nov 15, 2009 04:09 AM
EGCoupeVtec
Feb 11, 2009 06:00 AM
