Help with a possible clutch problem
Old Nov 26, 2008 | 07:55 PM
GrayStar1's Avatar
Default Help with a possible clutch problem
When i went to start my car today, i went to push the clutch in and the pedal went straight to the floor. I struggled to get it into any gear, it finally went after a lot of effort. I wasnt able to get it into reverse though. Have any ideas on what the problem could be?
Old Nov 26, 2008 | 10:53 PM
billyinse's Avatar
Default ?
clutch master cylander mine did this and i had fluid running down my firewall where tha clutch pedal goes through under tha dash
Old Nov 27, 2008 | 06:16 AM
GrayStar1's Avatar
ill take a look on the inside of the car, but i didnt see any in the engine bay on the firewall
Old Nov 27, 2008 | 06:33 AM
94EG8's Avatar
Seagull Management
You wont see it on the engine side. You'll have to get under the dash and take a look. Also pull back the boot on the slave cylinder on the transmission and see if its leaking, and check the hard lines and flex hose for leaks.
Old Nov 27, 2008 | 08:24 AM
GrayStar1's Avatar
It is leaking under the dash where the clutch pedal connects
Old Nov 27, 2008 | 08:32 AM
forcefedferio's Avatar
Then you will need a clutch master cylinder, fairly inexpensive part aftermarket, around $40.
gulfview
Jun 10, 2007 08:00 AM
sihonda
Nov 24, 2006 05:43 PM
snyderman5
Dec 26, 2005 11:30 AM
Turbo D17
Oct 20, 2004 03:28 PM
01-0720
Jun 27, 2003 07:17 PM
