CAN ANYONE TELL ME WHERE TO GET A PERFORMANCE BRAKE KIT!!!!
Old Nov 26, 2008 | 07:34 PM
DC4driver's Avatar
Default CAN ANYONE TELL ME WHERE TO GET A PERFORMANCE BRAKE KIT!!!!
MY STOCK BRAKES ON MY INTEGRA SUCK FOR THE WAY I DRIVE I NEED BIGGER AND BETTER BRAKES CAN SOMEONE PLEASE HELP ME???!!!!!
Old Nov 26, 2008 | 07:51 PM
pkdog167's Avatar
WHY ARE YOU YELLING?? ANYWAY THIS SHOULD GIVE YOU ENOUGH STOPPING POWER
http://cgi.ebay.com/ebaymotors/Bremb...Q5fAccessories
WHY AM I YELLING TOO?
Old Nov 26, 2008 | 08:02 PM
PandaSJ's Avatar
LOUD NOISES!!
haha jk
just check different web sites. go to like passwordjdm, andysautosport.com. just search around.
do the brembo
Old Nov 26, 2008 | 08:27 PM
lstegg's Avatar
lol.
Summit, Ebay, honda tech market place
Do you have stock rims? it will not have enough clearance...you need at least 17's
Old Nov 26, 2008 | 08:38 PM
90_EX_Civic's Avatar
first off, what type of driving is this? is it back road spirited driving, traffic type driving, high speed high way driving? what kind of brakes do you have on the car now? autozone rotors with autozone pads? a little more info.
Old Nov 26, 2008 | 09:07 PM
stoopid_1's Avatar
www.fastbrakes.com
Old Nov 26, 2008 | 10:30 PM
honda_fan06's Avatar
Brembo? Might help!
Old Nov 26, 2008 | 11:24 PM
pkdog167's Avatar
He might be a street racer?
Old Nov 26, 2008 | 11:48 PM
fc3srx729's Avatar
Try SummitRacing.com....
Old Nov 27, 2008 | 01:44 AM
redGSRguy's Avatar
Try getting better pads. Also try not driving like a moron.
Old Nov 27, 2008 | 06:18 AM
nsxtasy's Avatar
H-T Order of Merit
Why do you say that the stock brakes "suck for the way you drive"? What problem(s) are you having?
If your brakes are vibrating, the solution could be as simple as bedding your pads.
If you are boiling your brake fluid (the pedal gets mushy when the brakes get hot), the solution could be as simple as flushing your fluid with a higher-temperature brake fluid like Motul RBF 600.
If your brakes are fading (they get less effective when they heat up), then a pad upgrade may be all you need - especially if you are using crappy generic brake pads from the auto parts store. You can get excellent aftermarket brake pads that will give you a nice upgrade from the stock pads. I recommend the Hawk HP Plus brake pad.
Nothing you have said has indicated any need for replacing your brake calipers with bigger ones. And if you're not driving on the racetrack, you almost certainly don't need to do that.
Oh, and please learn how to use this key on your computer keyboard:
Old Nov 27, 2008 | 07:09 AM
danthemang3's Avatar
i just pm'd you i have a killer deal on some brand new brembo's
http://www.hondamarketplace.com/show....php?t=2437125
collkid
Mar 24, 2015 09:56 AM
mvp97gsr
Aug 18, 2006 05:08 AM
micrew
Sep 10, 2003 12:02 PM
Short_Shifter
Dec 27, 2001 12:57 PM
Reverend
Aug 30, 2001 08:16 AM
