Pulling with a hoist
Hey everyone,
I've got everything disconnected and the motor is ready to pull (D15b7). I see the the threaded holes, but I'm unsure as to what size bolts to use; as well as using chain or cable between them. Just looking for some advice.
Thanks!
Thanks!
are you talking about the engine mount bolts? they are 17's and getting the chain on it is my least favorite part of pulling a motor right next to the dam axles. i spent about 2 hours trying to chain my b7 lol.
thanks! What length bolt should I use? 2"? I don't want to bend the bolts and should I use washers on the end of the bolt so the chain can't slip off?
Washers are a must. Take your time. If you don't like how something looks, stop and redo it another way. Don't worry about bending bolts its a honda single cam its doesn't weight all that much.
civicsiguy21
Apr 15, 2014 03:08 AM
