aaaa can't get the lower control arm off
So you are talking about disconnecting your control arm at the lower ball joint? Get somebody to either pull up on the spindle or push down on the lower control arm while you wack at the end of the lower control arm. Enough hard hits should jolt it loose.
Put the nut back on, or if you have a beefier nut better(so you don't mess up the ridges where the cotter pin slides thro) ,thread it onto the bolt only like 6 turns and go to town on it with an impact hammer or a big ole' hammer.
Your best bet, short of a ball joint separator (which I don't particularly care for as they tend to rip the ball joint boot) is to have an assistant pry between the knuckle and LCA while you hit the side of the LCA where the ball joint stud goes through.
aka this:
this works every time for me. even after my friend broke a ball joint separator fork from autozone. just jack it up till you can shove something like a socket in the gap(i usually use this piece of a broken breaker bar i have). then lower the jack and kick the spindle downwards and it should pop loose
Geeeeezzzz guys, a BFH is not the answer.
You need this from ebay.
http://cgi.ebay.com/ebaymotors/BMW-B...ayphotohosting
There is a little raised area on either side of my LCA - that's where you hit it!
I spray everything with penetrating oil - smack it on one side for a while - then smack the other side a few times. After of couple of times of switching back and forth, it always pops out - no prying required!
Truthfully, I've NEVER had it pop out by just smacking it on one side or the other - you gotta hit it on both sides. At least, that's been my experience!
BTW, that type of seperator in the post above is GREAT! And, a smoookin' price too. I might have to pick up one of those...
[QUOTE=itsmejto;36527941]
x2. Full writeup on using this tool at http://honda.lioness.googlepages.com...novation#bjsep
Do not forget to remove, flip, and install the castle nut before using the tool. This keeps the bolt from collapsing, due to its lesser integrity caused by the cotter pin hole.
In the end I tried everything but the separater..then I took the whole hub/brake and moved it back and forth fairly hard so the bottom joint at the lower control arm was moving along with the threads in the arm anyways that and a big!!!! hammer and there u go POP!
Both are things I do. The wrench trick is great for that joint, the other I use for regular ball joints. Pickle forks are known to rip boots very easily, and a BFH is very easy to compress or bend threads. THAT saves you ZERO time.
