wont turn over, no power?
I just swapped a b20 into a eg hatch and I got the battery tested and charged at autozone and tried my friends battery and I get the same thing. I go to try to start it and the car won't turn over. I try it a few times then the power just shuts off, no headlights, interior light, or dash lights. Then I hooked a battery up a few days later n it did it again. Any ideas?
No dash, no starter hooked up and the headlights worked, then I put the dash in and didn't hook anything up and then I get no headlights. It just keeps working when I hook it up for a moment then all power just cuts out.
I had a problem like that when I swapped my b18. Check your harness, Engine Harness. Make sure there are no cuts, no butts, a cut somewhere along the wire could make it useless. And another thought could be your ecu. Good luck.
