Cam gear settings affect valve ajustment?
Old Aug 1, 2002 | 11:46 AM
Comptech98GSR's Avatar
Default Cam gear settings affect valve ajustment?
my cam gears are currently set to intake +2 ,exhaust -2 , will this mess anything up, when i go to adjust my valves later on this evening? or do i have to reset the cam gears back to 0,0, before i adjust the valves. thanks for the help.
Old Aug 1, 2002 | 11:40 PM
PYITR821's Avatar
Default Re: Cam gear settings affect valve ajustment? (Comptech98GSR)
no. the cam gears just adjust the cam timing they don't have anything to do with your valve adjustment. Larger more aggressive cams affect your valve clearance.
Old Aug 2, 2002 | 12:06 AM
akhom's Avatar
It seems to me if your gears are not set to Zero it than it is not really the TDC of each cylinder.
Correct?
Old Aug 2, 2002 | 12:28 AM
PYITR821's Avatar
Default Re: Cam gear settings affect valve ajustment? (akhom)
Correct?
Not correct. Just because your cam sprockets are set to Zero doesn't mean you are at top dead center. To be at top dead center the crank pully must be lined up with the mark on the block and the cam sprocket markings must be lined up and you can even check the distributer to make sure the rotor is on cylinder #1.
CPR
Jan 20, 2006 09:06 PM
Takumi Fujiwara
Jan 18, 2006 09:49 PM
Gump
Sep 20, 2004 03:09 PM
91integraLSVTEC
Aug 22, 2003 08:54 PM
Comptech98GSR
Aug 1, 2002 02:33 PM
