water got into engine?
Old Nov 26, 2008 | 04:11 PM
froogle29's Avatar
Default water got into engine?
i just realized that the person who did my swap didn't put a guard under the engine. i drove into a big puddle of water on the freeway today and i think water got into my engine. after driving into the puddle, 1st gear hesitated and felt like it was about to die out. 2nd gear hesitated a little bit, and then when i got into 3rd, it was fine. when i drive around locally, the engine has the same hesitation every now and then. should i stop driving my car or will it go away eventually? thanks
Old Nov 26, 2008 | 04:16 PM
devney's Avatar
a guard?
Old Nov 26, 2008 | 04:20 PM
b16_sol_707's Avatar
you talking about the splash guard? How big was the puddle you went through? I haven't ever seen a puddle big enough to cause the problem you are describing. And if water got in your engine, there's something else wrong.
Old Nov 26, 2008 | 04:30 PM
BryanM.'s Avatar
Resident Gearhead
Originally Posted by devney
a guard?
I'm sure he means splash guard (not the ones in the wheel wells).
Puddles big enough exist, hydrolocked engines are a common occurance.
The previous owner of my EJ6 smoked his motor by sucking up water into the CAI.
Old Nov 26, 2008 | 04:34 PM
abusedhusband's Avatar
change your air filter and clean or replace the spark plugs
Old Nov 26, 2008 | 06:23 PM
froogle29's Avatar
so changing the air filter and replacing the spark plugs would fix the problem?
Old Nov 26, 2008 | 06:33 PM
GYChris's Avatar
It may.
Remove your spark plugs and let it sit in the sun for a few hours. IF there is any water in the cylinders it should evaporate. Of course, make sure its not a rainy day
Old Nov 26, 2008 | 06:38 PM
R1C3Rxs's Avatar
did you have a cold air intake? I don't see how else water can get into your engine from a puddle and if that's the case then try a simple oil change.
Old Nov 26, 2008 | 07:45 PM
Frozen E's Avatar
H-T White Ops
Originally Posted by GYChris
It may.
The guy has been driving the car. I'm sure the heat of combustion already did a hell of a lot better job at drying the cylinders out than the sun will any day
Old Nov 26, 2008 | 07:54 PM
GYChris's Avatar
Bleh. Misread
Old Nov 26, 2008 | 09:16 PM
Bob Dole!'s Avatar
If the water was actually in your engine it would not be running right now, or be perfectly fine because of the combustion heat evaporating it all. Water could have also splashed up onto the distributor or something else electrical.
Old Nov 26, 2008 | 09:23 PM
Ruben19's Avatar
check distributor/alternator and electrical harness
xW01FxGANGx
14
Aug 20, 2014 04:36 PM
JDMegCoupe
Sep 12, 2006 05:49 PM
jiggagnome
Honda S2000
Jan 5, 2005 12:58 PM
SkylineGTR
Feb 5, 2004 04:45 PM
el402
May 19, 2002 04:06 PM
