symtoms for bad LMAs?
Old Nov 26, 2008 | 09:11 AM
fatpride111's Avatar
Default symtoms for bad LMAs?
what should I look for before I start tearing things apart to replace them?
Old Nov 26, 2008 | 09:14 AM
Dartanian's Avatar
They will tick like injectors or out-of-spec valve lash but louder.
Old Nov 26, 2008 | 09:15 AM
weavertime1's Avatar
clarify LMAs?
Old Nov 26, 2008 | 09:20 AM
damn, looks like I have bad LMAs... I've done like 15 valve adjustments and still never went away. How much would a set run me, and could I use thicker oil as a temp fix so I can drive my car home this weekend? Currently running 10w40
ahhh lost motion assemblys...gotcha!
Old Nov 26, 2008 | 09:24 AM
Dartanian's Avatar
Since it is dicey buying used ones, expect to pay upwards of $300 from the dealership. You could also use the cheaper Prelude ones if you shim them with a washer. There is plenty of information on this site about the proper sized washer, if you are so inclined.
You could bandaid it but I think you will be fine driving how it is as long as you intend to replace them very soon. I drove a long time with bad LMA's before I replaced them and beyond the annoying ticking, no damage was done.
Old Nov 26, 2008 | 09:30 AM
hmm, so i could at least drive it, and get it tuned like that? i down graded in cams, and its running rich as hell, but i wont have enough money to get it tuned if i replace the LMA's soon.
ill shop around, and see what i do.
Old Nov 26, 2008 | 09:32 AM
red_crx's Avatar
^^what ecu/ tuning software are you using?
Old Nov 26, 2008 | 09:36 AM
p30, and not sure what tuning software they used, i think crome.
whatever Zerohour in arlington uses...
Old Nov 26, 2008 | 05:22 PM
Bignel00's Avatar
300$ for some LMA , no way
vinuneuro
Sep 16, 2007 07:03 AM
amy
16
Apr 29, 2007 12:19 PM
