Smells like Hot IRON or Curling IRON left on
Old Nov 26, 2008 | 07:04 AM
aznromeo4u's Avatar
Default Smells like Hot IRON or Curling IRON left on
I did a google on it, but only one result came up that didn't explain much. Basically when I finish my drive, about 10 miles or whatever, my car smells like a hot iron.
It smells like it after a few days ago. It doesn't leak into the interior of the car. It's definately under the hood somewhere, close to the belt or engine. I just recently changed my spark plugs like a week ago.
Anything I should know or check?
Old Nov 26, 2008 | 12:08 PM
P_Adams's Avatar
You know, If I was there it would (most likely) be immediately identified.
Unfortunately, your discription doesn't bring to mind anything.
Are you noticing any fluid loss; like brake, engine oil etc?
Has anything melted itself to the exhaust pipe?
Any indications of it overheating?
Do the coolant fans continue to cycle after shutting off the engine?
P
Old Nov 27, 2008 | 03:56 PM
Duane_in_Japan's Avatar
Maybe the valve cover gasket leaking oil onto the exhaust manifold???
Old Nov 27, 2008 | 07:57 PM
bseriescrxsi's Avatar
that smell could be as duane said oil on manifold...could be a small exaust leak pre cat....it could be a number of things.....is it a sweet smell...sour...metallic type smell...more info would def help out
Old Nov 28, 2008 | 03:48 AM
doubleRdazz's Avatar
ok the problem that i've seen a ton of is the oil pressure switch leaking drops of oil right onto the exhaust
i've done a ton of them, thats on 90-93 accords tho, idk what year you have
the sensor is only $6 from honda
MHaz1701
Jan 25, 2018 07:39 PM
97milanoLS
Nov 10, 2010 07:56 AM
portaman03
Honda Civic (2001 - 2005)
Aug 4, 2010 12:31 AM
dafuzzbudd
Dec 31, 2006 07:28 AM
Wiseguy619
Mar 22, 2004 02:01 PM
