bad water pump?
and you said your fan turns on... hmm unless you install the thermostat wrong? i know if the pump is bad it would leak... from what i experience.
i know if the hose gets hard the fan should turn on and the temp. should drop. but in your situation it might be your pump. have a mechanic check it.
Take you radiator cap off and turn on the car...let it idle like that for a while. The only time I've had that happen is when something is restricting water flow or I still have an air bubble.
i tryed that it still doing the samething. Someone told me that it could be the headgasket..
b18cEggie
Feb 16, 2012 10:14 AM
streetracerjoey210
Aug 18, 2006 09:49 PM
