car shakes when braking
Old Nov 25, 2008 | 03:32 PM
noss88's Avatar
Default car shakes when braking
just bought a 93' del sol si and whenever i brake, the car shakes. any idea what the problem might be?
Old Nov 25, 2008 | 03:33 PM
revhardallday's Avatar
does the brake pedal pulsate as well?
Old Nov 25, 2008 | 03:36 PM
Noodler's Avatar
my pedal pulsates, rotors' warped?
Old Nov 25, 2008 | 03:37 PM
yep bad rotors will cause a pulsating brake pedal
Old Nov 25, 2008 | 04:45 PM
enycesam's Avatar
Rotors are warped. Should change the pads too while you're at it.
Old Nov 25, 2008 | 05:12 PM
IhateworkingoncaRs's Avatar
From my experience, when the car shakes it's usually the rears that are warped. If steering wheel shakes then it's probably the fronts.
Old Nov 25, 2008 | 05:16 PM
sde780's Avatar
does it feel soft when braking?
Old Nov 26, 2008 | 06:03 AM
shaking when braking could also be that the tires are unbalanced.
Old Nov 26, 2008 | 06:10 AM
fryguy190's Avatar
if the tires where unbalacnced it would shake at all times
Old Nov 26, 2008 | 06:14 AM
BrowNKiD's Avatar
u need a brake job. Unbalanced tires would shake at highspeed. Warped rotors shake while braking.
Old Nov 26, 2008 | 06:26 AM
00b20vtecoupe's Avatar
alighment would cause the shake at braking to but mostly rotors... probably the fronts....
Old Nov 26, 2008 | 07:31 AM
fryguy190's Avatar
most comonly its ur rotors. just be shure to get them replaced and also get new pads...
Old Nov 26, 2008 | 07:34 AM
philosofy1's Avatar
warped rotors, change them and you should be good.
i do recommend you get some good pads as well.
Old Nov 26, 2008 | 07:35 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Also check the wheels. Aftermarket or OEM? Also wheel balance. If it's aftermarket, does the wheel have lug nut cover? Was the wheel balance WITH the cover on?
I know you mentioned while braking, but sometime that only shows when there is load, such as braking.
Old Nov 26, 2008 | 07:38 AM
marcs1337's Avatar
wheel balance/alignment will NOT cause a vibration while braking...im 99% sure it's your rotors
Old Nov 26, 2008 | 07:46 AM
GoLowDrew's Avatar
Old Member
25 Year Member
I'll agree with you. My reply was based on my own experience back in 97 with my brand new Civic. I went cheap and got a set of used aftermarket wheels. I had the tire shop check everything. And there were no solutions.
There was vibration when I go over 80mph and when braking. Never had problems with OEM.
Got a new set of wheels, and no vibration. So there must be something wrong with the wheels. One, all four, don't know. So just want to throw it out there since the car is old, the wheels might be "old" too.
Old Nov 26, 2008 | 09:26 AM
sintype's Avatar
time for new rotors, and pads too while you're at it.
Old Nov 26, 2008 | 09:51 AM
noss88's Avatar
Default place to get them checked out?
dam, well anybody know where in around hayward area is a good place to get them checked? and also how much would it cost to get the rotors fixed + getting the pads changed?
Old Nov 26, 2008 | 11:55 AM
JDMh22eg9's Avatar
def. warped rotors try doing it yourself and save the $$
teggsr925
Mar 3, 2007 01:35 PM
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
Takashi1978
Apr 18, 2006 07:26 AM
dcb284
May 19, 2005 06:51 AM
speedehatch
Dec 3, 2003 11:57 AM
