manual tensioner question
Old Nov 25, 2008 | 02:16 PM
Prudz_lude's Avatar
Default manual tensioner question
Is this the correct tensioner?
http://cgi.ebay.ca/PRELUDE-H22-H23-F...3286.m20.l1116
What is the part number for it if anybody knows? I want to finish buying all my motor parts today so i no longer need to think about this crap lol.
Old Nov 25, 2008 | 02:45 PM
jay24k's Avatar
If you do a seach, someone posted all the parts. I'd personally only go OEM on the parts. Honda did update the auto-tensioner if you didn't know. I just did mine and used their new one.
Old Nov 25, 2008 | 02:51 PM
vinuneuro's Avatar
The manual tensioner conversion consists of many parts. Look at this diy/guide:
http://www.collectiveracing.net/crfo...ner-conversion
ImportRP.com sells all the oem parts you need together, for less than if you bought them separately (less than even Majestic).
Putting the belt on with the manual tensioner in an H22 is a total pita (total pita). I'd either get a new auto-tensioner or do this:
https://honda-tech.com/forums/honda-prelude-4/auto-manual-timing-belt-tensioner-new-cheap-way-auto-failure-failed-2197997/
Old Nov 25, 2008 | 03:07 PM
PirateMcFred's Avatar
While the manual tensioner might be a little tight to get the belt on I do not recommend using a new auto tensioner.
I have a friend that used mild cams and replaced all auto tensioner parts with new OEM components and after 40 K the tensioner's internal spring popped and stranded us 100 miles from home and bent his valves to add insult to injury.
Manual tensioner or a ghetto manual adjustable or none at all IMO.
Old Nov 25, 2008 | 03:13 PM
Prudz_lude's Avatar
omg.... i think i just made the biggest noob mistake. With a kaizenspeed balance shaft kit do i no longer need a tensioner? Pirate you said none at all, so i am assuming that is when the balance shaft is deleted, correct? If that is the case and the balance shaft is deleted don't i still need the part i posted though?
Old Nov 25, 2008 | 03:20 PM
vinuneuro's Avatar
The timing belt and balancer belt tensioner are two separate parts. You need both, if you're not using the balancer shafts, just reuse the H22 tensioner and stick a washer between the two tensioners to provide adequate clearance.
Old Nov 25, 2008 | 04:03 PM
Prudz_lude's Avatar
Gotcha, thanks. Any specific size for a washer? width?
Old Nov 25, 2008 | 04:05 PM
vinuneuro's Avatar
Doesn't matter too much, one that's just thick enough to clear the balancer tensioner from the timing belt tensioner.
Old Nov 25, 2008 | 04:06 PM
autoluder's Avatar
the accord sohc block uses the same manual tensioner parts as the h23, fyi....
Old Nov 25, 2008 | 04:57 PM
Prudz_lude's Avatar
Okay thanks guys, and thanks autolude for that fact.
Hdragger
Mar 19, 2011 05:18 PM
contractkiller
Mar 1, 2008 11:28 PM
umop-apisdn
Oct 30, 2002 05:14 PM
norice
May 22, 2002 01:48 PM
