B18C5 into a 97 Civic EX
Old Nov 25, 2008 | 11:18 AM
mattvivsound's Avatar
Default B18C5 into a 97 Civic EX
I have a friend who just totaled his '00 Integra Type-R USDM with the B18C5... it has 102k or so miles on it... He was rear-ended and bought the car back and I get first dibs at the parts.
What parts are needed for the swap? Engine, Trans & ECU of course, but what about the little parts?
What axles will fit? Do I use the ones out of the Type-R or do I have to find some from and 99-00 SI?
I know I need to find the driver's side motor mount from a 99-00 Si or Del Sol VTEC and the AC compressor mount from 97-01 CRV or Del Sol VTEC (if I want to the AC).
How much different is this swap from B16A? or B18C1?
Will I be swapping out the D16Y8 motor, it leaks from both the front and rear main seal.
Old Nov 25, 2008 | 11:27 AM
Ya Digg's Avatar
You cant use his mounts but you can use most of your stock ones plus one 99-00 si one which im not sure of but somebody will probably post it soon. You can use his axles but you would have to use his 5 lug setup because of the different size axles. Or you could get 99-00 si axles.
I want his 5lug brake setup though lol Can I have them?
Old Nov 25, 2008 | 11:43 AM
Thank you. 5 Lug might be going onto his '94, not sure, he did the rear disk (4lug) on it at the begining of the summer.
The next question...
Will can I use the EX engine harness or do I use the ITR harness?
Old Nov 25, 2008 | 12:26 PM
honda_hackett's Avatar
def get the shift linkage also.
Old Nov 25, 2008 | 02:07 PM
94EG8's Avatar
Seagull Management
You have to use the EX harness. BUT hang on to the ITR harness, they're excellent for installing an OBD2 ITR/GS-R engine in a '92 - '95 civic or '94 - '95 integra.
Its pretty much exactly the same as a B16A, a B18C1 involves marginally more wiring because of the IABs.
False. USDM ITRs use the same 32mm axles as all other '90 - '01 USDM integras and '88 - '00 civics (except '88 - '91 HFs and STDs). 98+ JDM 5 lug setups are 36mm, and obviously require 36mm axles.
Yep, make sure you get the linkage.
Edit, kinda forgot when I posted about axles, the '88 - '91 HFs and STDs don't use 32mm axles, they're smaller. My point about ITR axles in relation to the OPs swap still stands though.
Old Nov 26, 2008 | 03:54 AM
Originally Posted by 94EG8
False. USDM ITRs use the same 32mm axles as all other '90 - '01 USDM integras and '88 - '00 civics. 98+ JDM 5 lug setups are 36mm, and obviously require 36mm axles.
Thank you for that... that was one of my main concerns. I knew the JDM ITR had the bigger axles, but I wasn't sure about the USDM ITR.
Old Nov 26, 2008 | 05:20 PM
Ya Digg's Avatar
Thats what I was thinking too
mofo951
Jun 7, 2008 07:55 AM
95civiccpdx
11
Aug 18, 2007 11:57 AM
eL
Jan 12, 2005 04:58 AM
PtPuff
Apr 12, 2004 01:24 PM
slofu
Feb 7, 2002 03:42 AM
