tire ressure (M/T)
If your new at this, I would tell you to start where most guy's seem to, about 8-9psi then walk the pressure down so you get a feel for how the car moves at the top end of the track.
Don't just jump to low pressure. Better safe than sorry.
now I'm running it at 8 psi.... but I tried it at 5 and didn't fell the difference on the start. Only thing I felt that it was hard to stear the car on high speed. I turn the wheel to correct the direction, but she keeps on going the same way she wants
So I got scared and I went back to thos 8 psi.
But still what do you peeps run? the track is without rubber.
So I got scared and I went back to thos 8 psi. But still what do you peeps run? the track is without rubber.
the last 2 sets of slicks i've had mounted have not been holding their air. after 2 or 3 days they're completely flat. i think i'm gonna start using tubes to avoid that.
OP: how much hp does your car make?
I don't know the exact power of mine, but I do run ~12.5 (best 12.39) but still I want to improve my 60 ft as for now best was 2.03
what size are they? thats a terrible 60ft with slicks. you need to launch at higher rpm or something. with an average 60ft you'll be in the 11's so i'd say 8psi is a good tire pressure.
What do you have for traction bars, and suspension set up?
SkRiBLaH
10
Feb 16, 2004 09:25 AM
