Calling all DA integra owners!!! need some help
Old Nov 24, 2008 | 09:23 PM
Psychoteen101's Avatar
Default Calling all DA integra owners!!! need some help
Ive got a major electrical issue and i need somebody to trace a ground wire for me and try to give me some direction as to where it goes. I think i located my problem, i have a ground wire, i believe in all the wiring skematics i looked at they call it the steering column gorund, but i could be wrong. Just below the column, or its possibly attached to the column i have a ground wire that was cut and i cannot find where it supposed to go! Its right below the steering wheel under the dash and is screwed into either the steering column or a metal brace bar that runs alongside the column. Anybody that knows how to read a wiring diagram or can give me some direction as to what connector or component this wire came from it would really help me out. Or if anyone that has a teg that can take a look under there dash to see if they have the same ground wire. I have a 1990 GS.
Old Nov 24, 2008 | 09:28 PM
jhammond_82's Avatar
Reject Papi
whats not working? if its a ground, just run it with some other grounds. a ground is a ground.
Old Nov 26, 2008 | 11:46 AM
hmm just to name a few, horn, hi beams, lo beams, brake lights, tail lights, turn signals, hazards, radio, ect. Your probably the 5th person who has suggested that. I am not trying to find where to ground it to, im trying to find what the wire is supposed to be grounding. It its already attached the the chassis as if it were grounding something but the wire is cut. I need to find the component(s) its supposed to be gorunding.
Old Nov 26, 2008 | 11:11 PM
fc3srx729's Avatar
Bump...
Old Nov 27, 2008 | 04:32 PM
bump, still need the help!!
Old Nov 28, 2008 | 07:04 AM
be18see1's Avatar
why cant you just attach it to somewhere else on the chassis?
Old Nov 28, 2008 | 09:02 PM
yunghov's Avatar
try looking around the fuse panel
Old Nov 29, 2008 | 12:05 AM
lol, i already explained how this wasnt the issue.
It is already connected to the chassis. i need to know what component(s) its supposed to be grounding.
Old Nov 29, 2008 | 06:32 AM
the_augie's Avatar
why? if its still malfunctioning, its not the ground thats the issue. either that or its a bad ground.
Old Nov 29, 2008 | 09:22 AM
ricecooker415's Avatar
you guys don't even know what he is asking
Old Nov 29, 2008 | 10:52 AM
KILLAB17VTEC's Avatar
Genetically Gay
what color is the cut ground wire?does the cut connects to the dashboard?
Old Nov 30, 2008 | 06:04 PM
^^ True i dont think anyone is actually fully reading this...
THE WIRE IS CONNECTED TO THE CHASSIS ALREADY. iT HAS BEEN CUT, SO I DONT KNOW WHAT COMPONENT ITS SUPPOSED TO GROUND.
it is black, like a normal ground. It is connected to the steering column, or a brace near the column by a philips head bolts.
I dont need someone to try and figure out the problem. I need someone with a DA to look under there dash and see if they have the same ground and see where it goes. Thats all i want....
Old Nov 30, 2008 | 06:21 PM
BAYsikDC4's Avatar
is it close to the ignition? if so that should be the ground for your stock radio cassette player from what this diagram says.
Old Dec 1, 2008 | 04:03 AM
the_augie's Avatar
ok, i get it now, sorry. can you take of pic of where the problem is, so we know what to look for? or do you just want one of us to post an underdash pic of our car?
Old Dec 1, 2008 | 07:27 AM
I dont have a good camera or else i would. If somebody could post a pic that would be great. I can try to take a pic with my phone but i dont know how well it will turn out.
Old Dec 1, 2008 | 02:00 PM
Tatmonster's Avatar
just checked my DA. I have a black ground wire on the radio side of the column(right side). This wire is connected to a flat peice of steel on the side of the column. From there it goes directly into my wire harness loom/wrapping. The harness is attached to the side of the radio cage. This wire only looks to be about 5-6 inches long from the 10mm bolt to the end that goes into the harness. let me know what you find. Mine is a 91 Ls.
Uljima
May 4, 2014 10:24 AM
G0crxG0
25
Aug 29, 2006 06:15 AM
JspecFerio
Nov 1, 2002 12:15 PM
AllMotorITR
Aug 19, 2002 01:38 PM
