Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Transmission Fluid ?
Old Aug 1, 2002 | 08:19 AM
slickboy's Avatar
New User
Default Transmission Fluid ?
I know this might not be the ideal place on the site to post this, but since you guys that frequent this forum are the ones that are racing and pushing your cars regularly, I figured you'd be the best to ask. There have been many questions about whether or not to switch from Honda MTL, to a product like Redline MTL. Some people have said that it's great to run and their trannys feel buttery smooth. What I want to know is are there any adverse affects of swapping over..you know..any problems I could run into? I have a stock 95 LS teg with right at 100,000 on it. I do consider myself a more aggressive driver. The cost of the Redline is no biggie. I just want to know if there would be any problems after I switch over. I hope to run my car on the track at CMP this weekend if they are doing that, just to get a taste of what it's like...I've heard they are doing that as they did last time. My tranny fluid needs changed anyways..I figured, why not go for this stuff? Any help from yall would be great. Yall are the ones that know. Thanx!
Frank - who is one day hoping to join the ranks of the ECHC boys...and needs guidance to steer him down the road.
[Modified by slickboy, 5:20 PM 8/1/2002]
Old Aug 1, 2002 | 08:22 AM
J28S's Avatar
New User
Default Re: Transmission Fluid ? (slickboy)
There's been A LOT of talk about this in the past. Don't remember the threads though. Try searching and see what you come up with.
Some people live and die by Honda manual tranny fluid and others prefer Redline MTL or Mobile One tranny fluid.
Old Aug 1, 2002 | 08:25 AM
Willard's Avatar
Honda MTF = $15 a flush...
Do it every 10,000-15,000 miles. Your tranny will love you for it.
Will
Old Aug 1, 2002 | 08:31 AM
Doctor CorteZ's Avatar
Default Re: Transmission Fluid ? (Willard)
your paying too much brotha , I get this stuff for 3.30 a quart
10-15k.........**** I change that and adjust my valves every other oil change
Old Aug 1, 2002 | 08:32 AM
Willard's Avatar
Default Re: Transmission Fluid ? (Doctor CorteZ)
normal p33ps = $15 a flush.. at a normal interval..
p33ps like me = ~$12 a flush here every other oil change..
Old Aug 1, 2002 | 08:48 AM
ok , much better
Old Aug 1, 2002 | 10:16 AM
jasonb's Avatar
even use honda MTF with an aftermarket diff?
Old Aug 1, 2002 | 10:29 AM
Tyson's Avatar
Default Re: Transmission Fluid ? (jasonb)
it would depend on the diff.
what diff ? some may use different stuff , ask the company
Old Aug 1, 2002 | 11:15 AM
CivicSiRacer's Avatar
I heard using Redline MTL I might get more grinding with my 2000 Honda Civic Si. What do you guys think? Switch over or not?
Old Aug 1, 2002 | 11:24 AM
Willard's Avatar
Default Re: Transmission Fluid ? (CivicSiRacer)
like above...
"Honda MTF = $15 a flush..."
Old Aug 1, 2002 | 12:06 PM
bulldog_RS20's Avatar
Try 'em both. (not at the same time )
I ran events on both fluids and didn't notice a real subjective difference in either one. But I can tell you either were a vast improvement over the 10w-30 oil that was in there when I bought the car... I settled on Honda MTF due to the availability and cost... ('bout 12 bucks a flush is my cost)
I noticed an improvement in the 2nd to 3rd shift - even with my crappy syncro...
Greg
Old Aug 1, 2002 | 02:46 PM
jasonb's Avatar
Default Re: Transmission Fluid ? (Tyson)
OPM diff. OPM says either 10w40 or Redline. Balke says if syncros are good, then use Redline. If not, use Honda MTF. I assume my syncros are good, so I'll go with the Redline and see how that works out.
Old Aug 1, 2002 | 02:54 PM
slickboy's Avatar
New User
let me know what you think of it. Also...what do you drive so that I'll have a better clue of how it will affect my car?
Old Aug 1, 2002 | 04:46 PM
jasonb's Avatar
ITA prepped CRX Si. If I ever get the damn car wired up, Ill let you know what I think of it.
Old Aug 3, 2002 | 04:32 AM
illusion's Avatar
what does everyone use to refill the fluid in the tranny? the bolt sticks out sideways and it looks difficult....
Old Aug 3, 2002 | 08:39 AM
Mike P.'s Avatar
25 Year Member
Default Re: Transmission Fluid ? (illusion)
Pep Boys sells a pump (sort of like an oversized hand soap pump) that you can stick in your container and pump it in. I've been using one of these with success. You can also try one of those really long, flexible funnels.
Old Aug 3, 2002 | 01:15 PM
illusion's Avatar
Default Re: Transmission Fluid ? (Mike P.)
yeah i was told a syphon pump but it seems like it would take forever with that method
boosted03
Feb 1, 2014 07:14 AM
MtnCRX
Apr 4, 2012 06:31 PM
Mr.J37
11
Oct 16, 2010 12:18 PM
rybred
Nov 19, 2002 02:40 PM
InfamousRS
May 12, 2002 10:05 AM
