Running ls crank ls rods and ctr pistons in gsr bottom' will i have clearance issues
Old Nov 24, 2008 | 07:36 PM
915hondajunkee's Avatar
Icon6 Running ls crank ls rods and ctr pistons in gsr bottom' will i have clearance issues
Im running a gsr bottom end with ctr pistons Ls rods and rod bearings gsr mains and girdle and a gsr head. will i have any problems with clearance? due to the aggresive dome of the ctr's' and the ls rods and crank... please help before i assemble!!! has any one else done it ? and i know i have to cap the squirters... oh yeah its going in my 91 hf rex!!!!
Old Nov 24, 2008 | 08:09 PM
si vtec ftw's Avatar
well
if you have to ask
you shouldnt have a set up as agressive as that
you obviously dont know what you are doing.
thats REALLY high comp. for a 1.8L block.
but you shouldnt have clearances issues
so go ahead.
hope you have some good rods
Old Nov 25, 2008 | 03:51 AM
silverkorn's Avatar
http://www.c-speedracing.com/howto/c...c/compcalc.php
http://www.zealautowerks.com/
Old Nov 25, 2008 | 08:03 AM
jdmed3's Avatar
You wont have clearance issues but are you goin n/a or boost
Old Nov 25, 2008 | 08:32 AM
Furyof4's Avatar
You're going to have a couple problems with this setup.
First of all, ctr's stick out of the hole ~0.005" on a untouched block. If yours has been decked at all it will be more. With a stock headgasket and gsr head, that puts you at ~0.025" max piston to head clearance, i.e. NOT enough.
Second, you will be well over 13-1 CR. Not going to work well on pump gas no matter what people say.
If you haven't installed the pistons yet, GET RID OF THEM! Try b16 or itr pistons instead.
If they are installed, you can use a thicker headgasket as a bandaid to alleviate some of the above problems. Not the right way to go really.
Old Nov 25, 2008 | 06:31 PM
Old Nov 25, 2008 | 06:34 PM
i sold my ctr pistons today i bought a t3 t4 turbo want to boost with ls crank ls rods and gsr pistons in the gsr block completley changed my setup. just happend to run into that turbo go figure... any suggestions???????????? oh ported head and valve job is done wtha skunwerks intake
Old Nov 25, 2008 | 06:40 PM
sgallagher's Avatar
Just use the biggest possible cam you can find, like a stage 3. And make sure both side of your turbo is the same size.....The stock ecu should be fully capable if you install 720cc injectors.....Good Luck.
Old Nov 25, 2008 | 06:43 PM
sgallagher's Avatar
^^full of ****^^
Old Nov 26, 2008 | 07:23 AM
hackish's Avatar
I built and ran a GSR block for a while. I put the pistons on the milling machine and made small reliefs for the oil squirters. This didn't work out as they all cracked where I milled them - not enough stress relieving...
For my setup I used the entire LS rotating assembly. Beat the **** out of it but ultimately the LS rods didn't like 8250rpm 'cause I spun a rod bearing. It was all parts bin stuff anyway.
-Michael
fv8s
17
Jul 9, 2010 12:25 PM
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
1991islsv
Nov 21, 2008 07:25 PM
Coolest Dude Ever
Jun 8, 2007 02:39 PM
B18C-EJ1
Jan 19, 2002 11:45 PM
