OEM upper control arm bushings?
Anyone know of a source where I could get OEM upper control arm bushings? Honda doesn't sell them separately from the upper arms themselves.
I think Statracing or w/e the name is in the classifieds sells them, I do not think they are "OEM" because of what you stated but there is a source for replacements, I need to get a pair for my drivers front, the whole arm is not moving from the bushings being so shot....lol
Well I have the complete OEM replacement arms off eBay, the $70/pair ones, which came with everything, but the bushings are already squeaking, despite me preloading the bushings and spraying silicone lube on them.
I was actually thinking about swapping the original bushings off my old A-arms onto these, as I don't remember those ever making noise like these do.
remind me, werent you the one who thought under torqueing the upper control arm bushings (completely loose) was a good idea? isnt that why they squeeked?
anyway. try poly bushings. its single axis movement.
do you think the replacement bushings that a sponsor on this site sells are worth a try?
That's exactly what I need... I would get the whole kit if I could find it, and had the money to spend when I did find it.
http://www.buyhardrace.com or I think I've seen them on ebay as well. The pricing is the same. I went through the same thing because I didn't want to spend the money on more Mugen bushings. We're more fortunate now that other companies have started offering similar products compared to 5 years ago.
I would just buy them with the bracket. It's $55 for the pair. The installation probably sucks more than it costs to get them already installed. But, if you're really set on doing it yourself, then I have a full set that I can part out just the front UCA bushings to you.
https://honda-tech.com/forums/suspension-brakes-54/upper-control-arm-bushing-bolts-squeaking-1921887/
That site does sell the bushings but they come with the arm as seen here:
Worth the 55 dollars. Located in the bushings section
The only other way to get Hardrace Bushings in ur A Arms is with these:
http://www.specialprojectsms.com/ind...?productID=102
But they are pricey
But they are pricey
sorry patrick, but this VB search is much better... i do believe my memory was right.
https://honda-tech.com/forums/showthread.php?t=1921887
But they are pricey
But they are pricey
beefystud
Suspension & Brakes
Mar 1, 2017 07:03 PM
gwiffer
Suspension & Brakes
Feb 14, 2010 08:50 PM
