clutch pedal squeaking
Hi guys, my DB8 is having this issue when I push the clutch it squeaks and has more resistance. Its off and on but more often then not recently.
Throwout bearing? Clutch cylinder?
Help?
Help?
I would check the clutch master cylinder. Use a flashlight to see if it is leaking in the interior of the car. Mine started squeaking when the fluid leaked passed the seals. I changed it out for a new oem one and haven't had a problem since.
Can you help me and post a pic of what I need to look at?
I see the slave but not sure if there is a leak.
I was told that I have a leak in my oil pan but they could not see a leak anywhere. They mentioned it might be elsewhere that is trickling down to the pan.
Anymore help would be greatly appreciated.
it is not the cmc, its the input shaft. Its right under the Clutch Slave Cylinder, get under the car, pull the boot back and lube it. Do not use wd40, it is a degreaser.
it can also be the release spring on the clutch, but most likely where i described at first.
