Stripped lug nuts.....
Old Nov 24, 2008 | 03:42 PM
thunderlips's Avatar
Default Stripped lug nuts.....
bought a crx and was taking the tires off..... one of the lugnuts is stripped and is just spinning and CANNOT get it off! how on earth do i get this tire off?
Old Nov 24, 2008 | 04:36 PM
91dxsedan's Avatar
try putting something like a pry bar to get leverage on it while turning it
just a thought
Old Nov 24, 2008 | 06:27 PM
doubleRdazz's Avatar
yea i would try to pry on the wheel from the wheel while someone tries to unbolt it at the same time
if that doesnt work then you are going to try to cut the stud off with either a torch or a sawzall
good luck
Old Nov 24, 2008 | 08:19 PM
gator88's Avatar
good luck
dont use either of those. Especially the torch. If you have to cut, a wafer wheel on a die grinder. Try having someone really **** the wheel sideways to bind the stud while you smack it with an impact. This has worked for me before on a snowmobile trailer with 2 like this.
Old Nov 24, 2008 | 08:34 PM
B18GLC's Avatar
this process can suck i've come across it all the time at work. if nothing else take the other three lugnutz off and pull out on the opposite side of the wheel for "binding" and have someone hit it w/an impact gun. you might want to have a vicegrip on the back side of the stud.
Old Nov 24, 2008 | 10:05 PM
skidmarkroyalty's Avatar
autozone sells special impact sockets for stripped lugs. my my friend had the same problem a while back and ended up buying one.
Old Nov 25, 2008 | 12:21 AM
2slow4stock's Avatar
Yeah.. for stripped lugs. Not stripped with nut on it still. Just go buy a new stud no so you can install it when you get it off. Have you tried impact gun with leverage from backside?
Old Nov 25, 2008 | 06:08 AM
88Hatchy's Avatar
is it on the front or the back?
Old Nov 25, 2008 | 09:34 AM
yeah i have on stripped on the back and one on the front wheel... i think for the one in the back i turned it so hard the stud is rotating around in the rotor.....it looks tricky to get to. so far no luck with leverage and i dont own anything that could cut at that angle. i may have to go buy something.
Eclectia
Jun 16, 2013 11:56 AM
pinkspider
Mar 7, 2010 07:55 AM
e jay one
Dec 19, 2006 03:52 PM
ImNaked06
Sep 24, 2005 11:10 AM
Tomek
Sep 13, 2002 01:46 PM
