B16 Timing Question and yes I've checked faq.
Old Nov 24, 2008 | 12:30 PM
noidg101's Avatar
Icon6 B16 Timing Question and yes I've checked faq.
Hello fellow honda teachers,
Okay I've looked at the faq and the honda man.ual. My question is How do I time my b16. I have all the factory manual info and illustrations. My question is do I line up the white mark on the pulley which is tdc to the timing cover pointer or do I line up the red mark on the pulley with my timing cover pointer. The reason Im asking is because Im running really high idle and when I hook up my timing light Im no where near the red center line on the pulley.
Any and all help will come with a high five
Thanks,
Noidg
Old Nov 24, 2008 | 02:10 PM
grog's Avatar
first before you set/check the timing your motor needs to be fully warmed up and idleing at 800 rpms, if its not fix that. A jumper needs to plugged into the service/adjusting connector.
Also make sure that you are using the timing light correctly, it took me a bit to figure out mine.
Line up the red mark to get the timing/BTDC. I beleive if you line up with the white mark it should read 0 degrees.
Old Nov 24, 2008 | 02:23 PM
1990hondacrx's Avatar
i cant tell u but this site will help u he explains very fast and easily showing u how to do it and has a video of him doing it on Evans tuning site hes changing cams but skip that and just follow his how to time part of it all
http://www.evans-tuning.com/tech_articles.html
go to the how to swap b series camshafts
Old Nov 24, 2008 | 02:29 PM
sgallagher's Avatar
You have the white mark which is all by itself and you have the red mark with a notch on either side. The white is TDC, the red is the desired degree.
If you are using an adjustable timing light, **** or digital reading where you can change the timing, then you will be looking for the white line. Set the timing light to the desired degree. You adjust the distributor advance or retard until the white line lines up with the pointer on the timing cover. If ou then set the light to 0* You should match up with the red mark.
If you are using a basic timing light, then the red mark is your desireable timing mark. Adjust the dist. to match the red mark to the pointer. the marks on either side or the red are +/- 2*.
AS PREVIOUSLY STATED....YOU MUST HAVE THE CAR AT OPERATING TEMP, CORRECT IDLE AND HAVE THE SERVICE CONNECTOR JUMPED TO SET TIMING CORRECTLY!!
Old Nov 25, 2008 | 12:03 AM
noidg101's Avatar
Okay thanks for the help. Now to finish my question. When I install my timing belt do I line up my timing to pulley on the red or white mark? And of course with both cam gears pointed up.
hondachris1994
Jul 29, 2008 11:48 AM
sohc-8
Dec 26, 2005 04:19 PM
Lei Siew Long
Mar 31, 2004 12:43 PM
slowd16z6
Mar 13, 2004 02:20 PM
King_j
Aug 14, 2003 07:40 PM
