Car making whistling noise while on has pedal
Hello,
I just noticed today when I put my foot on the gas I hear a whistling type noise coming from the car. However, when I put my foot on the break the noise stops. What can it be? Its an 2002 Honda Civic with about 250k on it
Thanks
Thanks
I hear it from inside - could be from outside the car not sure - I left the car on in park and there was no noise just only when its on the gas - I also hear a clunking noise as well
if it's coming through the speakers, it's a grounding issue....other than that, the only advice I can give without hearing it is check your drive belt or maybe you have a super stealth turbo you just don't know about yet...lol jk.
It would be best if you could isolate where this whining noise is coming from...I mean, there's a lot of things that could make a whining noise. It would suck to spend money fixing something that someone on here recommends and have it not be the issue at all.
have you had the alternator replaced? also check your a/c belt tensioner. if you want you could have meineke peek under the hood at your belts to see if they're prematurely warped. if you haven't replaced the alternator then the bearing might be the cause of the noise.
gators113
Transmission & Drivetrain
Jun 24, 2019 02:51 PM
JDMchuckles
Mar 6, 2003 08:02 PM
