Is the replacement ECU compatible
Old Nov 24, 2008 | 07:38 AM
Kipper-Fish's Avatar
Default Is the replacement ECU compatible
1992 Honda Civic EXV with 1600cc SOHC VTEC engine and automatic transmission.
Previous stock ECU, now dead, is 37820-P28-C50.
Available, replacement stock ECU, not yet installed, is 37820-P28-C52.
My question: Is the replacement C52 compatible with the previous C50?
Old Nov 24, 2008 | 07:44 AM
slo_hatch's Avatar
i believe that determines your automatic vs. manual ecu...since its different then its probably for a 5 speed. if i remember correctly thats what the last 3 letter/numbers mean. so no...it wont be compatible.
Old Nov 24, 2008 | 08:03 AM
Slo_Hatch, thanks for your very quick reply.
In the last three digits of the ECU part number:
C = intended for Canadian market
5 = intended for Automatic transmission
The last digit:
0 = Original version, Revision 0
1 = Revision 1
2 = Revision 2
etc, etc
I am unable to establish the differences between Rev. 0 and Rev.2
Can you advise?
Old Nov 24, 2008 | 10:46 AM
TomO's Avatar
It will be compatible with your motor. The revisions are just minor changes Honda made to the programming and tables in the ECU.
Old Nov 24, 2008 | 11:08 AM
94EG8's Avatar
Seagull Management
Yep, this is the answer you're looking for.
Old Nov 25, 2008 | 09:43 AM
TomO and 94EG8,
Thank you both for the postive response. Will now go ahead and install the replacement ECU.
Robert,
Surrey, BC.
Amber Rock
Honda Civic (2001 - 2005)
Jan 25, 2016 08:38 AM
colbyem2
Feb 27, 2012 12:03 AM
tdc
Feb 12, 2002 05:58 PM
