Stock ITR lugnut question?
Old Aug 1, 2002 | 06:14 AM
Nate B's Avatar
Default Stock ITR lugnut question?
Are these lugnuts acorn seated? Will they work with Rota Slipstreams or do I need a new set? If you read my other post, disregard this one...Thanks guys.
Old Aug 1, 2002 | 06:16 AM
BDiddy's Avatar
Default Re: Stock ITR lugnut question? (KILLERB18)
I thin kyou need Volks or another set of Acorns. The stocks arent goign to work. They dont on my Spoonies and you have the same rim... so 1+1=2 right?
Old Aug 1, 2002 | 06:20 AM
Nate B's Avatar
Default Re: Stock ITR lugnut question? (Megatron)
How don't they work? Do they not tighten down enough?
Old Aug 1, 2002 | 06:25 AM
BDiddy's Avatar
They dont seat into the wheel right and dont give enough contact patch with the wheel to nut. The acorns fit into the wheel properly and give maximum wheel to nut contact patch as well as a good strong bind to hold the wheel on. The regular nuts dont fit into the dimple right and leave a less desireable contact patch.
Old Aug 1, 2002 | 06:31 AM
Nate B's Avatar
Thanks a lot for the info, basically do you think I can get by with the stock one's for one night? I have an appointment in 2 hours and I will be getting a new set of lugnuts tonight when I leave work. Thanks again for your help
Old Aug 1, 2002 | 06:32 AM
BDiddy's Avatar
I would advise against it. Get the nuts first. Its not a good idea.
Old Aug 1, 2002 | 07:06 AM
Nate B's Avatar
Thanks again, I just found an autoparts store that has the acorn lugs I need so everything should be all good...
Old Aug 1, 2002 | 07:54 AM
Asahi's Avatar
For liability reasons no one is gonna tell you it is a good idea.
I will admit to running millinia wheels at an auto-x torques to 90 ft-lbs with stock lug nuts with no issues. ADn then got my rays lug nuts in the mail the next day.
Old Aug 1, 2002 | 07:55 AM
uNF$@#!'s Avatar
Default Re: Stock ITR lugnut question? (Asahi)
odd, from what i recall, the stock itr nuts are spherical shaped, which will <u>not</u> seat properly on rota's, which require an acorn (edit: Asahi says tapered is the proper term) shape nut...
HTH.
[Modified by Soup ****, 12:01 PM 8/1/2002]
Old Aug 1, 2002 | 07:59 AM
Asahi's Avatar
Default Re: Stock ITR lugnut question? (Soup ****)
there are only 2 kinds of lug nuts tapared and acron. acorn are spherical so sounds like you describe the same thing.
Most wheels require tapered except Hondas.
Old Aug 1, 2002 | 08:00 AM
uNF$@#!'s Avatar
you might be right. but never the less the nuts wont seat right.
what ever shape the kyokogen lug nuts fit fine.
Old Aug 1, 2002 | 08:05 AM
Asahi's Avatar
True. And Rays and spoons.
Old Aug 1, 2002 | 08:06 AM
Nate B's Avatar
are those tapered or acorned...I'm getting confused...
Old Aug 1, 2002 | 08:11 AM
Asahi's Avatar
Tapered
Old Aug 1, 2002 | 01:25 PM
nsxtcjr's Avatar
New User
True. And Rays and spoons.are those tapered or acorned...I'm getting confused...
Honda/Acura OEM wheels and OEM lug nuts: Acorn (spherical).
Aftermarket wheels and lug nuts: Tapered.
Do not mix the two.
Old Aug 2, 2002 | 04:12 AM
kkim's Avatar
Default Re: Stock ITR lugnut question? (nsxtcjr)
here's a good source for lugnut info...
http://www.mtdealer.com/ph_fasteners_2002.cfm
Root of all Evil
May 1, 2014 06:31 AM
young geezer
Jul 2, 2011 12:46 PM
boostede36
May 30, 2008 09:05 PM
beastman@
Oct 25, 2007 11:04 AM
