turboing a h22 prelude..
Old Nov 23, 2008 | 10:45 PM
f22sexkitten's Avatar
Default turboing a h22 prelude..
i have a 98 prelude with a h22a4 in it. i was wondering what the safest way to go is as far as turbo charging it.. what should i do to the engine to make it last with it being turbo charged?
Old Nov 23, 2008 | 10:51 PM
dagle's Avatar
sleeves, low compression pistons, rods, engine management. those would be a good start.
Old Nov 23, 2008 | 11:01 PM
HondaKyle's Avatar
Don't push the motor to its limits. Get a very good solid tune on it with a Hondata or AEM EMS. The tune is EVERYTHING.
Old Nov 23, 2008 | 11:36 PM
H24Turbo's Avatar
if you get a solid tune and keep the boost at 7-8 psi you shouldn't have any issues. do a compression test first though. or you could build the motor. i blew the ringlands on my first motor.. its fully built now.
Old Nov 24, 2008 | 11:29 AM
teefunk01's Avatar
Dont skimp out on fuel mods. A sufficient pump, fpr, injectors, and a good management system should be the bare minimum
Old Nov 24, 2008 | 12:19 PM
Widebody93's Avatar
Don't push the motor to its limits. Get a very good solid tune on it with "CROME or ECTUNE" HONDATA and AEM EMS is WAY TOO OVERPRICED. The tune is EVERYTHING.
Fixed it for ya
Old Nov 25, 2008 | 12:18 PM
Tytank7's Avatar
8 psi max.....(stock)
Old Nov 25, 2008 | 12:23 PM
98vtec's Avatar
moderator emeritus
PSI MEANS NOTHING
Old Nov 25, 2008 | 01:59 PM
HondaKyle's Avatar
Ask this question in the forced induction thread. They will be more knowledgeable then in here...
Originally Posted by 98vtec
PSI MEANS NOTHING
Yes and no
Old Nov 25, 2008 | 02:01 PM
gearhead313's Avatar
25 Year Member
PSI MEANS NOTHING
thank you.
x2
Old Nov 25, 2008 | 03:28 PM
Ludster's Avatar
Good EMS and Good Tune.. is a start..
k20powered
Mar 10, 2010 07:08 AM
1badITR
Jan 1, 2003 02:19 PM
rluder21
Nov 8, 2002 08:54 PM
