Brake lights stay ON with CAR OFF HELP!
Old Nov 23, 2008 | 05:56 PM
EG6DGK's Avatar
Default Brake lights stay ON with CAR OFF HELP!
Hey what's up guys well like the title says with the key out car off the brake lights are still illuminated!!! I checked the brake switch and sprayed a little WD40 (to un-stick it, even though it wasn't really stuck I think) and nothing. I just pulled the fuse so my battery won't die. Any ideas guys?
Thanks!!!
Old Nov 23, 2008 | 06:07 PM
doubleoazn03's Avatar
i would just totally replace the brake light switch all together. It doesnt cost much anyways.
Old Nov 23, 2008 | 06:30 PM
EG6DGK's Avatar
Daaamn it I just replaced it like a month ago!
Thanks for the reply though man.
Any other possibilities guys?
Old Nov 23, 2008 | 06:50 PM
str8venom99's Avatar
try adjusting the switch, it may not be contacting the brake pedal arm. if not replace the switch
Old Nov 23, 2008 | 06:53 PM
z6hatchboy's Avatar
as said just try replacing the switch/adjusting it, if this doesnt work trace the switch wire and see if its shorted to ground. The tails have a constant 12v to them all the time but the brake switch completes the ground for them to work
Old Nov 23, 2008 | 07:05 PM
robfrmny21's Avatar
did you install the new switch correctly a month ago. did you make it snug enough?
97SS
131
Jul 23, 2021 01:30 PM
babybreese
Aug 16, 2017 12:33 PM
pythoner
May 21, 2008 11:30 AM
89dxhunchback
Oct 18, 2005 08:54 PM
