need help want little info civic 96hb
hi guys
i have 96 hb civic and the window regulator is broken so some one told me that i can install the window regulator of 95 civic hb so i like to know is it true will it fit?
hello guys i install the window regulator its same there was only 2 diffrence look in the picture where i put the arrow you need to make one hole for the bolt on the door pannel.. which in the older civic is little far.http://i267.photobucket.com/albums/i.../regulator.jpg
and the shaft of 95 civic where you put the handel is little short so for that on the door panel where you put the handel its little bumpy ..so what i did with the plyer i remove the bumpy part without damaging the cloth so now the handel is working perfactly and its not noticeable.
http://i267.photobucket.com/albums/i.../doorpanel.jpg
Pyr0TeK
Mar 30, 2007 05:52 AM
