Precision or Rc Injectors
I currently have rc 750's maxing me out at 399hp. Just picked a t67 and I need bigger injectors. I seen 1000 precisions for a good price, but wasn't sure if they were as good since rc's were like 70-80 bucks more. Is anyone running on precisions and are satisfied with there performance? Or should I get rc's? Thanks in advance!
420whp on rc750's with still more to go.
if you are using all the fuel of a 750cc injector and are making less than 400whp something else might be wrong.
you should be able to get close to 500whp with some good fuel pressure.
Well I didn't mean maxing out. I should have worded it better. I am running Neptune, with aem fpr, walbro intank, aem fuel rail with a b&m fp guage. I know I will need larger injectors is what I should have said. I think on the rc site, the 750 are only good upto like 425 or so. I wnat to push around 500 with the t67
you should check out the bosch 1000cc saturated fuel injectors. there is a post on the first page about them. they seem to have some really good spray pattern and can easily idle/run the engine with some good air/fuel ratio without sputtering.
i think i will be getting those in the spring time.....to bad 1000cc is way overkill for what i want but will work great for your application.
here: https://honda-tech.com/forums/forced-induction-16/injectordynamics-com-bosch-1000cc-2433327/
ahh that is the trade off.....i do believe those Bosch injectors are about 400+ per set of 4. (no resistor box required)
i personally like RC injectors. but many others use precision with great success. but either RC or precision in 1000cc will require a resistor box.
Yeah, that's what I don't want to do, but would have to. I checked out that thraed and those Bosch' sounfd really good. I may just save up for those. Nothing beats reliabilty. I damn sure don't need my car idleing rich just to sound good at idle. lol The Bosch' could be hooked up the way i have my 750 rc's now? Thanks for the insight.
So you guys saying that if I order some 1000cc injectors I will need a risistor box in order to install them on my car, I have a LS/Vtec that have been buying parts to complete my turbo set up and the injectors is one of the items that I was waiting to get more info on them.
I will be using a bullseye T04B 60-1 so I was wondering if the 750cc will ok for my set up or should I go for the 1000cc just to be on the safe side.
RC makes 750cc injectors that does not require a resistor box. the 750cc should be easily safe up to around 450whp. 500whp would be at is extreme limits.
the new bosch 1000cc injectors do not require a resistor box and they perform well at low duty cycle making them very nice and easy to tune and 1000cc's should support over 650+hp easily if not more.
Honda Gen
Jun 10, 2009 10:35 PM
