ej2 GSR redline at 6500 RPM?
Old Nov 23, 2008 | 05:16 PM
jeffnerette's Avatar
Icon2 ej2 GSR redline at 6500 RPM?
hi fellow h-t members. i tried this post before but no was able to help but its tikking me off. i have a 93 ej2 with obd1 GSR in it. i have a stock obd1 p72 ecu, i also have no CELs, but my VTEC engages at like 3700 RPMs and i redline at 6500 RPMs. someone please help i would really like my car to redline at 8200 RPMs.
thanks again in advance.
Old Nov 23, 2008 | 05:19 PM
b16_sol_707's Avatar
Have you tried a different ecu?
Old Nov 23, 2008 | 05:21 PM
BaconLettuceTomato's Avatar
sounds like the ecu is not stock
Old Nov 23, 2008 | 05:23 PM
That's what I was thinking too.
Old Nov 23, 2008 | 06:16 PM
i tried my sohc ecu(p05) but redline is the same(6500 RPM) just no VTEC
Old Nov 24, 2008 | 09:01 AM
come on people please.
Old Nov 24, 2008 | 09:05 AM
koa's Avatar
koa
Id open it up and see if its been chipped. It sound like it has but i have no idea why the redline would be so low.
Old Nov 24, 2008 | 09:10 AM
i did and it has no chip in it. it looks stock to me. no soldering anywhere.
Old Nov 24, 2008 | 09:17 AM
koa's Avatar
koa
Ok not being an *** but do a better job looking.There is solder on every inch on ecus. To better understand weather or not your ecu is chipped check the link and tell us what you think when your done. http://www.xenocron.com/install/Xenocron-ECUs.htm
Old Nov 24, 2008 | 09:20 AM
koa's Avatar
koa
wow what kind of gauges do you have? didnt think of tht. Stock? Big huge tach? a sweet egay jdm one?
Old Nov 24, 2008 | 09:30 AM
LMAO. sounds like something i would say. no i have my stock tach. the only thing is that my car used to be auto and i converted it. so the tach is an ex auto tach. you think that would cause the problem?
and about the soldering i ment no soldering anywhere out of the ordinary like uhh where the chip is suppose to be.
Old Nov 24, 2008 | 09:48 AM
heres a pic of tach and ecu code(im being lazy to take it out of the car and open it. it cold outside)
Old Nov 24, 2008 | 09:58 AM
oh yeah my cars got a super rare jdm bodykit to and a fast and furious jdm spoiler that came off off vin deisel's car to help me with downforce. LOL
but on a more serious note. please help me figure it out.
Old Nov 24, 2008 | 10:03 AM
Mr.Chow's Avatar
I'm running a 95 si cluster in my 92 cx...I have a gsr swap as well running a stock p72 and my limiter hits at aorund 7500rpm....thing is my tach is off..its actually hitting 8200ish but indicating otherwise just because its something either in the cluster itself or somewhere else...you should, I would hope, be able to tell the difference in sound between 6500 and 8200rpm..try hooking up an external tach and see if you get the same results.
Old Nov 24, 2008 | 10:12 AM
when it hit redline at 6500 rpm it sounds like it should be at 8200 but im not 100% sure. but i dont have an extra cluster to test out
Old Nov 24, 2008 | 11:35 AM
Mr.Chow's Avatar
alsolutely! just given what you've told me I'm 90% sure its your cluster.
Old Nov 24, 2008 | 02:27 PM
turbodelsolb16a2's Avatar
so your cluster can do that to you...cause i have a 97 civic ex with b16a.....and a stock p2p ecu with vtec controller and it redlines at 7k rpm....and sometimes t 6k rpm but it sounds wierd when it redlines at 6k rpm....
Alfa164S
Jul 24, 2011 12:05 AM
Tylerjdmgsr
Jul 27, 2009 11:57 AM
jeffnerette
20
Nov 15, 2008 10:33 PM
polishedturd
Dec 6, 2007 10:24 AM
pK1spooled
Nov 18, 2004 09:06 PM
