Running too cold for vtec to work properly?
Old Aug 1, 2002 | 04:13 AM
b16aeg's Avatar
Default Running too cold for vtec to work properly?
I think I have a stuck thermostat. (I'm going to replace it today after work)
It must be stuck open because the car seems to not even get into normal operating temp on the gauges (I know the temp gauge works because it does move a little here and there if I'm in traffic or what not).
So would a stuck open thermostat cause the car to run too cold, therefore not getting hot enough to let vtec engage?
Thanks.
Old Aug 1, 2002 | 05:02 AM
Canuk_SiR's Avatar
Default Re: Running too cold for vtec to work properly? (b16aeg)
If the thermostat was open all the time, it would just take longer for the coolant to get up to temp. Maybe its youe temp sensor?
Old Aug 1, 2002 | 05:19 AM
b16aeg's Avatar
Default Re: Running too cold for vtec to work properly? (Canuk_SiR)
The problem is that the car will get warmed up and vtec will work fine.
If I drive it hard and I'm in vtec for a while (or just up in the rpm's for that matter)
vtec will cut out almost like its studdering and the harder I drive it the more and more it will cut out until finally vtec stops working completely.
Could the oil be getting hot enough from driving hard that the oil pressure actually drops, therefore causing the pressure switch to not allow vtec to work?
Does the weight of the oil have an affect on this. (I think I'm only running 30 weight right now)?
Thanks
Old Aug 1, 2002 | 12:13 PM
Chiovnidca's Avatar
Yes.
Old Aug 2, 2002 | 02:44 AM
ITR18's Avatar
Default Re: Running too cold for vtec to work properly? (Chiovnidca)
Id have to say that there is something wrong with your oil preasure because obviously if you are accually able to get into VTEC once the car is "warmed up" as you put it (key word being "warm") then it seems like there must be a problem in maintaining oil preasure...all i can say is that i would be careful and not be hitting VTEC until you know what the problem is
Old Aug 2, 2002 | 02:55 AM
kinesistech's Avatar
I have to agree with the cold engine theory. A stuck open thermostat and a fast moving car makes cold water. I wouldnt hurt to verify the sensors but, the gauge and the computer both have they're own so its probably not that. And, of course it wouldnt hurt to verfiy proper oil level either.
Old Aug 2, 2002 | 04:41 AM
b16aeg's Avatar
Default Re: Running too cold for vtec to work properly? (kinesistech)
Well, here's an update....
Installed a vafc yesterday.
vtec still "cuts out" - So the only thing left to be the problem could be the vtec soleniod itself, right?
My theory being that the vafc doesn't "care" about temp, or oil pressure, or speed.
So the only thing left to cause this problem would be the soleniod.
I put a wire from the positive terminal to make sure that it clicks and works, and it does. But, is it possible for the soleniod to actually wear out. If the soleniod works upon magnetism, then is it possible to wear out and lose its "hold"
What do you think?
Thanks
TheBook
Nov 14, 2012 08:40 AM
MyDeeCee2
Feb 3, 2011 06:35 PM
supersonic782g
Jun 25, 2009 01:33 PM
74celicagt
Feb 2, 2006 12:30 AM
H22EKCOUPE
Feb 18, 2003 09:34 AM
