F23A1 compression check
Old Nov 23, 2008 | 01:23 PM
iplayloudly's Avatar
Default F23A1 compression check
so i posted earlier about my problem with constant piston slap, so today we ran a compression test and they seemed pretty high.
1= 220
2= 220
3= 205
4= 225
Is this normal? If not, would that affect anything?
Old Nov 23, 2008 | 02:07 PM
P_Adams's Avatar
You're well within range, and you've nothing to be concerned with. A 7% difference between cylinders is within normal ranges. Now, if it looked like this:
220
170
210
220
THEN I would be concerned and would have asked you to perform a wet compression test.
As it stands right now, the rings and valves are doing their job.
P
Old Nov 23, 2008 | 02:14 PM
220
170
210
220
P
the real reason i ask, the standard is around 178 i think. Is mine unusually high?
Old Nov 23, 2008 | 02:19 PM
P_Adams's Avatar
Does it use any oil?
Old Nov 23, 2008 | 05:02 PM
not that i can tell
Old Nov 23, 2008 | 06:13 PM
impound's Avatar
did you do it hot?
Old Nov 23, 2008 | 06:41 PM
yes
Old Nov 23, 2008 | 08:00 PM
P_Adams's Avatar
Specifications F23a1:
  • Bore × Stroke: 86.0 × 97.0 mm
  • Displacement: 2254 cc
  • Valve Configuration: SOHC, 16 valves, VTEC
  • Compression ratio: 9.3:1
  • Max power: 150 hp (112 kW) @ 5700 rpm
  • Max torque: 152 ft·lbf (205 N m) @ 4900 rpm
With the 9.3:1 compression ratio, I would expect 190/220 (ish) for a psi.
The reading you are getting are healthy and within acceptable range.
A compression test is not so much what the numbers are, but the difference (if any) between them.
P
climb_on
Jul 29, 2007 03:40 PM
Hoodwinked
May 14, 2004 08:28 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
311
Dec 14, 2002 12:18 PM
LostGsr
Jun 15, 2001 12:29 PM
