battery drain
Old Nov 23, 2008 | 09:42 AM
eg_21's Avatar
Default battery drain
hi, i have a 92 civic vx with a gsr swap in it, when i bought the car, the cluster lights worked at times but mostly they wouldn't work, all gauges worked except the speedometer which would jump up and down sometimes, anyway i notice the climate control buttons light up after i turn car off key off ignition, that's the only thing i notice so far, radio is fine is just the climate control buttons that will stay on, of course i leave them off but it still drains battery in a couple days, i checked wires behind cluster and everything seems fine, also check alternator and ecu wiring and radio, everything looks good.
do you think is the ignition switch?? but if that was the case then the radio would stay on as well when car is off. what do you guys thiknk??
Thanks
wing.jai
13
Dec 29, 2013 05:29 PM
stiffinEK
Mar 4, 2008 09:55 PM
blac00si
Jun 13, 2006 10:54 PM
Bailhatch
Apr 5, 2004 02:18 AM
