GSR A26 IAB Solenoid not hooked up
On my P72 ECU after I completed my swap, I wired up VTEC and the knock sensor, made sure everything else was in the right spot. The only thing that's not hooked up right now is the pin for A26 because it's blank. Accordingly to FFSquad diagram it's for the IAB Solenoid. If this isn't wired up what will it do in the meantime?
What will it do? The IAB (intake butterflies) won't work correctly. They will be open all the time.
It's simple to do. If you have the knowledge to wire up VTEC and the knock sensor, I would recommend wiring up the IAB sensor if you're running a P72 because VTEC switches over at a lower RPM (4400) w/that ECU. You'll gain some low-end torque as well.
Well I traced the pink/blue wire to the harness which on the other side was a red wire. I hooked power to it and trace it I believe to A18 I think, just switched it to A26 and it's good to go. Thanks!
NotNew
15
Aug 31, 2008 10:13 PM
Cynical 1
Sep 23, 2002 04:41 PM
