OBD2 Distributor install question...
Old Nov 23, 2008 | 06:48 AM
c1v1c98's Avatar
Default OBD2 Distributor install question...
If the distributor can only slide into the end of the cam one way, why does the number 1 piston have to be at TDC when you install the dist.?
What ill effects can be expected if the distributor is not installed with the number 1 piston at TDC?
Old Nov 23, 2008 | 10:58 AM
117's Avatar
117
I've never set #1 to TDC to install the distributor. Never had a problem
Old Nov 23, 2008 | 11:04 AM
Dartanian's Avatar
x2
Old Nov 23, 2008 | 11:45 AM
c1v1c98's Avatar
Well, alright then. I installed my distributor without being at TDC, so I was just wondering if it really made a difference.
Old Nov 23, 2008 | 12:29 PM
dagle's Avatar
i thought 5th gen OBD2 dizzy's timed themselves through the ECU
W O T
10
Oct 11, 2005 03:16 PM
racekar
Oct 19, 2004 09:32 PM
98JDM_Type_R
Aug 20, 2004 03:02 PM
98JDM_Type_R
Aug 20, 2004 02:54 PM
