Gauge cluster needle removal
Old Aug 1, 2002 | 01:11 AM
Red GSR's Avatar
Default Gauge cluster needle removal
Long story short, friend had indiglos installed. Did a bad job and needles got messed up. Returned to stock but needles now show incorrect speed.
I managed to pull out the cluster no problem but how do I go about recalibrating it? It doesn't have to be precise or anything. The rpm meter is still correct more or less so I decided if I get to 3k rpm on 5th gear it would equal 60 mph. But I can't take off the needles. Does anyone know how I can take off the needles?
Old Aug 1, 2002 | 05:34 AM
Charlie Moua's Avatar
Default Re: Gauge cluster needle removal (Red GSR)
the needls should just come off(pull evenly on the top) When i did my gauges i had to mess around with the needles for everything to fit but when i got done i just put it all together and it bacially reset it self(gas, tem, speed, tach)
Old Aug 1, 2002 | 09:54 AM
dohcsideSi's Avatar
Default Re: Gauge cluster needle removal (Charlie)
use 2 spoons pry up, one on each side
Old Aug 1, 2002 | 10:26 AM
integra-modder's Avatar
Default Re: Gauge cluster needle removal (dohcsideSi)
good idea...
raverx3m
Nov 10, 2013 08:18 AM
4drSi
May 26, 2007 01:05 PM
Cee_mon
Mar 10, 2007 11:04 AM
